Question about Frigidaire Dryers
How to change the rear drum bearing frigidaire model fex831cs0
  • 84 Answers
SOURCE: Rear Drum replacement - White Knight tumble dryer model 38AW
go with the info, and if possible the old bearing--- to the appliance parts store and they will likely help you!!!
Posted on Dec 15, 2009
heatman101
  • 43501 Answers
SOURCE: Need a diagram for a dryer belt for frigidaire fex...
Here you go...
Fridgidaire and GE Dryer Belt Replacement
http://www.fixya.com/support/r4245914-fridgidaire_ge_dryer_belt_replacement
heatman101
Posted on May 22, 2010
caroldon
  • 17130 Answers
SOURCE: I have a Frigidaire Combo
This can be due to the belt failing and hitting against to produce the noise or even if the main motor had failed.
You will need to check inside the washer to confirm the observations.
the belt can be changed easily once you have taken out the broken one , buy the same size according to the sample . It can be rolled into the main pulley and then after aligning with the motor pulley manually turn the pulley as the belt will be dragged into the slot.
Posted on Mar 28, 2011
heatman101
  • 43501 Answers
SOURCE: Loud Squeaky Performa Dryer Mod#
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Jul 14, 2011
  • 29 Answers
SOURCE: What's your problem?CHANGE REAR BEARING
How do you know you need a rear bearing? You need to remove the front of the dryer, then loosen the belt from the tensioner near the motor pully (draw yourself a picture so you can put it back on the same way), take out the drum. The carrier is on the rear wall and the ball that holds the drum up is on the back of the drum
Posted on Oct 19, 2011
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
Frigidaire affinity front load dryer
You need an upper felt and a rear drum bearing. If you buy the felt make sure you get the special adhesive to install it. The squeal maybe part of this or it could be the rear drum bearing. You can learn how to replace the rear drum bearing here in the article I wrote. http://gomestic.com/do-it-yourself/how-to-replace-a-frigidaire-dryer-rear-drum-bearing/
Jan 29, 2014 | Dryers
Frigidaire FEX831CS0 dryer is making a thumping/knocking sound while running. It still heats and rotates but makes this noise. I checked the belt - it has a tear in it - but I don't think this is the...
The drum rides on rollers-the bearings probably have failed or there is a flat spot on one or both-I would check them-Iwould replace all at the same time-cheers Denny
Oct 24, 2013 | Frigidaire FEX831CS Top Load Stacked...
What's your problem?CHANGE REAR BEARING frigidaire dryer model # aeq7000ego
Oct 19, 2011 | Frigidaire Dryers
I have a frigidaire stackable washer/dryer model number FEx831cs0. The washer is working just find but the dryer for a few weeks has been making the worst screeching sounding in the world. I am not sure if...
A loose belt often makes a squeak that pulsates with the clothes hitting the paddles in the drum. It's probably the upper drum glide or rear bearing. If it's a constant screech coming from the front, it's probably the glide. If the noise seems to be in the back, suspect the bearing. You might check for a sock or something small that is stuck somewhere between the drum and the dryer.
Glide: http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/916658?modelNumber=FEX831CS0
Bearing kit: http://www.repairclinic.com/PartDetail/Drum-Bearing-Kit/1851?modelNumber=FEX831CS0
Neither are very difficult to repair.
Other parts for your machine:
http://www.repairclinic.com/Shop-For-Parts?s=t-%20FEX831CS%20-%3d%3d
Good luck.
Feb 28, 2011 | Frigidaire FEX831CS Top Load Stacked...
Bearings that support the drum on my front load washer are making
It is replaced from the rear of the drum, beneath the pulley.
You need a bearing puller tool and some common sense.
Take photos as you work, that aids reassembly.
Jan 06, 2018 | Frigidaire GLTF2940ES Front Load Washer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
