Question about Compaq Armada M700 Notebook
Power problem when i plug in my charger to my compaq presario v2000 nothing happens anymore. I used to be able to move the cord around and get it to turn on, now it wont do anything. Help please
    Problem Solver:
  • 18 Answers
Sounds like a broken wire in the power supply lead that finally can't be juggled any more; Buy a new one, or more cheaply, cut off the connector to the laptop before the break (you'll need to test continuity with a multimeter that a friend will lend you) then cut out the length with the break, and re-join by soldering or with proper, safe connectors and insulate safely afterwards. DON'T DO IT YOURSELF IF YOU'RE NOT SURE YOU CAN DO IT SAFELY.
Posted on Oct 25, 2008
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Won't turn on, but the charge icon blinks 3 times
It has enough juice in the battery to light up the lcd lights but not enough to turn it on. Could be the power supply. Consult a reputable service center and have it checked out. Good luck.
Aug 04, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Aug 04, 2009 | Compaq 389897-001 - HP/ Presario V2000...
The last time I used my Compaq Presario v2000 I had it on battery power. The battery died and now that I am trying to use it I have the power adapter plugged into it and I get nothing when I hit the power...
This problem is either due to your power adapter, wall plug or the back of your lap top where the power adapter goes into. My guess would be the power adapter, they are infamous for going bad. Try wiggling the cord that connects to the power brick (black box) from your lap top.
Jul 08, 2009 | HP Compaq Presario V2000 Notebook
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 battery
if the computer will turn on with it plugged into ac power than it is most likely the battery. batteries on these machines are cheap. Mine died after a year
Jan 18, 2009 | HP Compaq Presario V2000 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Compaq presario v2000 amd turion64
question.....does the motherboard you use support the powersource? that is one thing i would look into and have had problems with with many pc,laptops,etc. lemme know what happens
Aug 05, 2008 | HP Compaq Presario V2000 Notebook
Power supply malfunction?
Remove the battery and try the cord again. Complete with the moving it around. It sounds like you have already diagnosed the loose DC plug adaptor, but the battery could have gone terminal.
Apr 17, 2008 | HP Compaq Presario V2000 Notebook
Computer will not start
Disconnect battery and unplug from power, test for voltage on power cord and re-insert, hold down power switch. If nothing try battery without power cord. Still nothing (no lights, no sounds) then it may need system board replacing.
Sep 19, 2007 | HP Compaq Presario V2000 Notebook
Compaq Armada M700 Notebook Logo
27 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
