Question about Sony KV-32S26 32" TV
Need to find a way to replace or repair the plastic housing around the front of the tv which has been cracked.
I am trying to find the plastic housing found around the front of the tv tube. There is a complete crack right through the spot where the SONY insignia can be found. Since this shroud or housing helps to support the tube I am afraid the tv is going to sustain further damage without somekind of immediate repair or replacement.
Try and find similer or an old TV so u can use the cover
Posted on Nov 06, 2006
Housing around blade cracked, need a new one
Sorry but seriously doubt that you can buy a housing alone . try some good glue .
Sep 14, 2015 | Ultimate Chopper Food Processor
Crack in plastic radiator housing
don`t know what your asking.if your asking can a plastic radiator housing be repaired no it will need replacing.if your asking what could cause it,it could be just a weak area in the plastic,or excess coolant pressure.
May 21, 2011 | 2000 Acura 3.5RL
I have a 98 lincoln town car executive and I need to know how you change the thermostat
1. drain coolant
2. remove engine cover
3. remove the 2 bolts from water hose connection (upper rad hose connecting to)
4. remove o-ring and thermostat
5. repeat in reverse order
Feb 05, 2010 | 1998 Lincoln Continental
Mixer has a broken gear or tooth in the head.
Hi. You have experienced the problem that many hundreds of kitchenaid mixer owners have. No doubt your mixer began having problems while you were mixing bread or cookie dough. Kitchenaid advertises that these mixers can handle these types of dough, the brutal truth is they cannot, for one very important reason. The cheap plastic transmission housing has failed, and as a result has caused damage to your mixer's transmission.
This cheap plastic part supports two of the most important shafts and gears in your mixer and has no business being installed in a high priced mixer. Heavy doughs place enormous stresses on these gears and shafts and this plastic part is not up to the task, Kitchenaid knows this of course, but refuses to issue a recall notice.
If your mixer is still covered by warranty, call Kitchenaid's so-called customer satisfaction dept. and demand a mixer replacement with a METAL transmission housing.
If out of warranty, unplug the mixer and don't use it. Remove the silver band from around the head of the mixer, then remove the four screws that secure the cover, remove it. At the front top of the mixer locate the transmission cover, if it's made of a shiny metal, you're in luck. If it's made of plastic, examine it carefully for cracks around the mounting screws or anywhere else on the housing. If you find cracks, you have found the culprit that has caused untold internal damage to yoúr mixer
If you are up to the task of repairing it, go to the kitchenaid.com website and do a search for your model's parts catalog. Download it, it will help with the disassembly and reassembly of the mixer.
You'll need to remove virtually all of the old grease. Remove the trans. components and wipe them clean, in order to correctly assess damage. When you determine which parts need replacement, you must insist on a metal housing when ordering parts. Try mendingshed.com for parts. You can also order parts from Kitchenaid...Just be prepared to wait at least a month for them to arrive from Kitchenaid! "For the Way It's Made"?
Finally regrease with Chevron FM ALC EP-2 a Food Grade lube.
Be sure to tell the people at Kitchenaid what you think of their cheap plastic housing!
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 05, 2009 | KitchenAid KP2671 Professional 6 Series...
6qt Pro Kitchenaid Mixer not mixing
Hi. If you goto the Kitchenaid website you can do a search for the parts catalog for your model of mixer. Download the catalog. It will assist you in disassembling your mixer.
Remove the silver band around the top of the mixer. Remove the top cover and look at the top front of the machine and locate the transmission housing. If it's plastic, carefully inspect this housing for cracks. If you find cracks in this housing, IT is the source of your troubles. This cheap piece of plastic has no business being installed in a high-priced mixer. Your machine probably failed when you were mixing heavy bread dough or cookie dough. When this cover cracks, it can strip the worm gear shaft, its bearings and the bearing seats. It happened to me, and many thousands of other users I expect. Insist on a metal trans. housing for your replacement.
You may be able to have Kitchenaid pay for these parts even out of warranty, just don't tell them that you opened it up. Take it to an authorized repair place and let them assess the damage. Use their estimate to confront Kitchenaid. Be persistent in your complaint, keep asking for a manager to get involved in your case. They paid for my replacement parts even though I was 5 months out of warranty. The higher up you go in the management dept., the more likely you are to have them pay for your parts.
Once repaired, sell it ASAP!
Feb 16, 2009 | KitchenAid KP2671 Professional 6 Series...
1998 Limited Grand Cherokee Radiator Problems after front end rebuild Front Differential problems as well
yea when you start moving the front suspention around you probably put the core support in a bind and cracked the plastic housing on the radiator, these cheap plastic radiators now days are a joke, and as for the front differential problem explain in more detail
Aug 26, 2008 | 1996 Jeep Cherokee Country
Replacement of front plastic screen
well, unless you are really really lucky and could find the same model at the local tip, you will need to ot\rder and replace the part through a repair center or parts center of sorts, quite costly
Aug 05, 2008 | JVC HD-61FN97 61" Television
Cracked
I'm afraid that you will have to replace the base unit, part #62577, would sell for around $25. Once it cracks, then it is weak and will affect the brush roll and belt.
Dec 30, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Cracked glass on front glass
if the tv turn on this will tell you that the plasma panel itself is ok. if it is ok then the fron glass is replacable. this is just a standard piece of glass so i really wouldnt spend tons of money hiring someone else to order one and install it.
Nov 05, 2007 | Televison & Video
Sony KV-32S26 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
