Question about Canon DR-7580
Need to remove the glass plate safely from my canon dr-7580
mohanchennai
  • 490 Answers
SOURCE: Faded images canon Dr 7580
Clean the glass thoroughly. Try Automatic settings and try various contrast levels in mamual mode.
S. Mohan
Posted on May 21, 2009
  • 3 Answers
SOURCE: CANON DR 7580 SCANNER : SCANNED IMAGE HAS A LIGHT
Assuming the document going through the scanner looks normal, there are a few things to check. If you open Capture Perfect, you can adjust the contrast and brightness as well as the thresholds. Sometimes different toners react differently to the scanner...paper is a big thing too. Multi-part forms can be tricky to get the settings adjusted so you pick up enough of the text but not that on the other side. If it's still messing up, you can try and get it serviced. Ikon is nationwide and can help out.
Posted on Jun 09, 2009
mohanchennai
  • 490 Answers
SOURCE: In need of a service / parts manual for Canon DR
You can get spares from http://www.scannerparts.biz/servlet/StoreFront
Service Manauals are little difficult to get, need to search the web patiently. Be sure of the site, there are quite a false sites that rob you of your credit card details. S. Mohan
Posted on Jul 20, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon DR-7580 misfeeds intermittantly cutting off
Select 'auto detection of page size instead of a fixed size.
S. Mohan, India
Posted on Mar 05, 2010
Testimonial: "We did that and still have the same problem. I am wondering if it could be the rollers. Thanks."
mohanchennai
  • 490 Answers
SOURCE: I have a canon dr-7580
Use Qumatool to check if all the sensors are working okay. Normally sensors dont fail, there must be a small piece of paper (like the 'dot' of pre-printed stationery) sticking somewhere.
S. Mohan
Posted on Sep 07, 2010
My Canon DR 7580 has image void in the front image. Looks like two void columns. The Image reader is clean. Can the upper and lower imager be swapped to see if the problem is the upper imager?
You cannot swap upper and lower images. You can scan the page twice (in duplex mode) by reversing the same. Ensure which side is giving perfect output.
DR 7580 is a CONTACT scanner and hence the paper has to touch the glass surface properly. There are two full sized rollers, just above/below the scanning module, which does this job. Ensure that they are proper and there is enough pressure, press and release 3-4 times to check it is stuck.
S. Mohan, Chennai, India
May 19, 2011 | Canon DR-7580
Need the part number for the scanner led array? getting lines on scans not all led's are turning on and just need to order the new array. Its the upper array on the canon scanner dr 7580
MG1-3616 is the part number for the entire reading unit. I am not aware if only the LEDs are available separately. It is very unlikely that only some LEDs are working. Ensure glass is clean.
Feb 17, 2011 | Canon DR-7580
Canon dr 7580 erroe 32
If the main board (CPU PCB) not installed properly you get this error.
S. Mohan
Oct 11, 2010 | Canon DR-7580
Canon dr-7580 error 32
According to the service manual if 6080 and 9080c cpu/motherboard are interchanged this appears.
Oct 05, 2010 | Canon DR-7580
Canon dr-7580 scanner how to initialize cis
If the Black lines are jaggered and are vary in size with different levels of brightness, then most likely it is scratch on the glass. If the lines are sharp and perfect and does not change when different brightness is chosen, then it could be failure of CIS module (Try this under B&W mode). To the best of my knowledge there is no concept of initialising the CIS, you may need to clean the Shading sheet.
Apr 10, 2010 | Canon DR-7580
Canon Dr-7580 not scanning two sided.
Check if you have chosen the 'duplex' option.
S. Mohan
Jan 11, 2010 | Canon DR-7580
Canon dr 7580 is not scanning multiple pages.
Check if you have selected 'multipage' option. Then you will get only a single file, but with multiple pages.
If your question is that the second or subsequent pages are not pulled in for scanning, then you need to change the rubber rollers.
S. Mohan
Sep 30, 2009 | Canon DR-7580
In need of a service / parts manual for Canon DR 7580 scanner
Jul 01, 2009 | Canon DR-7580
S. Mohan
May 03, 2009 | Canon DR-9080C Path-Through Scanner
146 people viewed this question
old marine
old marine
