Question about Kenmore Washing Machines
Kenmore Elite purchased 2003 model#110.24942300 rinses while in spinning cycle
Fills, washes, rinses fine; however, spin cycle is left too wet as water is entering machine as machine is in spin cycle.
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Model 110 washing machine will not stope the agitate cycle
If the washer fills but does not agitate or spin, this is usually a symptom of a bad lid switch. The switch will either be located on the right hand side of the washer tub opening, or in the rear on the left hand side under the console. If you have a right hand model, examine the lid and make sure the plunger that activates the switch when it is closed is still intact. The plunger is a plastic piece that is physically mounted on the lid. Sometimes they break off. If the plunger is intact, try taking a small object (like a screwdriver or popsicle stick and push down on the lid switch contact while the lid is open and the timer knob started. You should hear a distinctive "click" when you push on the switch and the washer will agitate. Sometimes the switch can become loose and no longer make good contact. If this is the case, simply tighten the two mounting screws on the tub opening. If the switch relay is not clicking you may need to replace it. The part runs about $35.
If you have the left hand style switch that is enclosed under the console, the contacts are closed by a small metal bar on the back of the lid. Sometimes this bar becomes bent or loose. Open and close the lid and listen for a distinctive "click". If you don't hear anything, you may need to adjust the metal bar, or replace the switch. This style of switch tends to cost a bit more.
If you can provide me with your model number (located under the wash lid along the tub opening), I can research the part number for you and let you know where you can get it and give you step-by-step instructions on how to replace it. This is a simple repair job that the average consumer can perform with simple instructions and a few household tools. First, determine if this is the cause of your problem. Post back with comments and let me know if this helps you.
Posted on Nov 24, 2007
ronaldo_ross
  • 1056 Answers
SOURCE: Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Posted on Jul 01, 2009
  • 58 Answers
SOURCE: kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
jsrock516
  • 5911 Answers
SOURCE: kenmore model 110 will not drain or spin?fills
Check your lid switch. The symptoms of your washer stopping at the rinse cycle is a commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop and compare. If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing so I can provide you with better assistance. Please include your model number if different from the one listed. I hope this information is helpful to you.
NOTE: "110" is not the model number. This is the prefix on the model number that identifies the manufacturer of your washer. 110 indicates the washer was manufactured by Whirlpool.
Posted on Nov 26, 2009
  • 311 Answers
SOURCE: My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Posted on Jan 28, 2010
A kenmore elite washer won't spin on rinse cycles. Does fine on first wash cycle, fills up for first rinse and then won't spin after that either on first or second rinse.
There are two plastic gears on each end of the motor inside the washer. One of them broke. These gears make the tub spin. They are inexpensive. it is rare that both gears broke but have both of them replaced. Then you don't have to worry about the second gear breaking in a few months.
Dec 31, 2014 | Kenmore Washing Machines
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
MY KENMORE ELITE MODEL 110.2497 WONT CYCLE TO WASH, SPIN OR RINSE CYCLE . WHEN I TURN IT ON IT FILLS BUT DOESNT CYCLE AN FURTHER, IT JUST MAKES THIS CLICKING NOISE....
hi..the reason to this problem is probably due to the
motor control board.
check this out..
thank you..
kindly rate my response..
Jul 20, 2009 | Kenmore Washing Machines
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
Washing Machines Logo
23 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
