Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Bizhub c252 jam when making double sided copies , original just stop in the middle of the glass after the first scan it won't go to the second scan
SOURCE: Can not make bizhub c252 scanning trough e-mail feature
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Posted on Oct 10, 2007
SOURCE: renolio
your problem maybe caused by a thermistor near the pressure roll in the fusing unit (the red roll).
Try the follow procedure and if it doesn't fix call minolta service.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Posted on Mar 30, 2008
taminol
  • 62 Answers
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
Posted on May 26, 2009
herminio_hal
  • 210 Answers
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
Posted on Jul 10, 2009
SOURCE: Where can I get instructions on how to replace the
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Nov 27, 2009
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
Konica Minolta Bizhub C252 FTP Scanning Problem
I'm not sure what you want to do, but I have installed various BizHub machines.
User ID, is exactly what it is... Used to monitor and manage individual users.
Which OS is the machine you want to scan to?
Depending on machine, I will hint Konica Minolta FTP Utility...
Mar 04, 2014 | Office Equipment & Supplies
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Make double sided copies bizhub 350
use the control panel select 2 side from single sheets or double side original
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 31, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Black lines running down on the Konica Minolta bizhub c252 copier?
Does this happen when you print? does this happen when you make copies on the big glass. Does this happen when using the document feeder?
Jan 23, 2012 | Minolta Office Equipment & Supplies
What causes a line down the middle of copied pages
There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on.
May 24, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Single copy out of double original w/o using paper feeder
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
