Question about Kenmore 74972 Gas Dryer
Gas Smell For the last few loads all of are clothes smell of gas. Is there solution for this problem ?
    President:
  • 878 Answers
Lester, more than likley you have a venting issue. Check to see that the dryer vent is not pinched off or the vent outlet is not clogged or blocked by something. Ninety percent of the time this problem is associated with a clogged venting system. Remove the bottom panel by taking a putty knive on each end, pushing on the clips and pulling the panel forward. Check to see how much lint is by the burner. Unlpug the unit to check this. Catriver..post back.
Posted on Aug 16, 2006
I smell gas it running what would cause this ?
This problem requires IMMEDIATE attention! The igniter is failing periodically but the smell of gas indicates the gas valve is stuck partially open.
Feb 09, 2015 | Washing Machines
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
Burning chemical smell coming from the gas dryer
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
heatman101
May 28, 2010 | Kenmore Elite HE4 Electric Dryer
When drying clothes in my gas dryer, you can smell gas upon opening the door. If the dryer is not running, you do not smell a gas odor. Sometimes our clothes also have a gas smell.This just started a week...
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Jan 17, 2010 | Estate TGDS740JQ Gas Dryer
Clothes smell like gas
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
Jan 24, 2009 | Kenmore 43142 Front Load Washer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Smell
Have you recently painted or finished any woodwork or floors? A gas dryer will smell like gas when the vapors from paint or finishes reacts with flame. It can smell like gasoline.
Nov 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Gas smell from dryer
your igniter needs to be replaced.
Jan 26, 2007 | Kenmore 74842 Gas Dryer
Kenmore 74972 Gas Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
