Question about Zanussi WJS1265W Front Load Washer/Dryer
How to enter configration codes
Can some one please help me to reconfigure my PCB as i have fiddled with the skip and start buttons by pressing them togather and switching the machine on i tried to enter the 16 digit code on the cover of the PCB but i am unable to do it right as i am not aware of the correct procedure to reconfigure my PCB thanks for help.
  • 4 Answers
Wow,it's a little difficult,if u have the knowledge of physics or math,maybe u can have a try.Good luck!my E-mail rww_2006@126.com welcome to contact me
Posted on Aug 21, 2009
When you press the button to select the right cycle the time comes up, you press start you can hear the door click to lock but then nothing happens!! either the code F12 comes or it says 'door' even though...
Dear claughrin
The problem in Fault code F12 can be EEPROM on the main module PCB which is malfunctioning.
A new EEPROM installation is possible and will be a cheap repair.
Alternativaly you have dump on the PCB boards and you have to blow dry the cards in order to remove the dump. (This requires opening the washing machine)
Please be careful, take off any plugs, Electricity is dangerous!
Regards!
EngineerGR
Apr 08, 2008 | Washing Machines
Zanussi zfw 1631 w skipping through programmes straight onto drain from wash. has been coming up with an error code e30
I'm going to take a stab at the filter on the empty pump being blocked.
I have tried to find an error code that matches for you and loads of forums talk about a possible blocked pump filter (Though I have seen a motor fault mentioned too!).
Try checking the filter out, it's the biggest cause of questions being posted on this site for washing machines
Jun 29, 2011 | Zanussi Washing Machines
I have installed a new LCD screen on my acquasmart WL80T65CW1 and teh csreen now shows fault code 9. Please advise how to get rid of it and resize machine. Thanks.
Hi
If ever you replace the display PCB or the main controller PCB then you must set the size of the machine in to the memory of the controller. This should of been in the instruction sheet that came with the display.
This Is Fault Code 9 ,which indicates Size setting or
size error . When you changed the display did you size your machine to the new display module? Did you get the re-size set of instructions with the new display board? Ring up where you brought the display from and i"m sure they can help.
If this appears in your screen it will be necessary to set the size of the Aqua smart....
1. Press and hold the SPIN button, then press the POWER button until three beeps are heard.
2. Press the FABRIC SOFTENER button once to size the machine.
3. Press the POWER button.
If nothing works you need to reset your machine, please check the bellow link to get the manual and check page 18 and 23 for the reset instructions.
http://www.fisherpaykel.com//admin/pdfs/pdf_usecares/3731_LCDLED_Aquasmart_FINAL.pdf
Please get back to us if you have further query else please accept the suggestion.
Mar 20, 2011 | Washing Machines
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
I have an e50 fault flashing on the display
Hello, E50 is relating to the main motor,it could be the brushes,tacho or something more serious.,try checking the brushes first follow these instructions.
Hold the start/pause and skip/reset together then press the on/off button keeping the other 2 buttons held until you get chasing lights,now release the first 2 buttons.Now press the fabrics button until the light goes down t60 degrees or the pump cuts in.Then take it on I think step by step until an error code displays make a note, to cancel hold the 2 buttons start/pause and skip/reset and the error code should go but if it reappears then the fault is still there.
Thanks
Jun 14, 2010 | Zanussi ZWF1430W Front Load Washer
We have code e50 on the front off it how do you get it off
E50 is relating to the main motor,it could be the brushes,tacho or something more serious.That error code will not clear until you can find the problem causing it,try checking the brushes first.If you want to try to clear it first follow these instructions and you may get the exact error code displayed if so then get in touch again with the new error code.
Hold the start/pause and skip/reset together then press the on/off button keeping the other 2 buttons held until you get chasing lights,now release the first 2 buttons.Now press the fabrics button until the light goes down t60 degrees or the pump cuts in.Then take it on I think step by step until an error code displays make a note, to cancel hold the 2 buttons start/pause and skip/reset and the error code should go but if it reappears then the fault is still there.Good luck
May 03, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
Nov 21, 2008 | Zanussi ZJ1217 Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
56 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
