Question about Panasonic CT-36D32 36" TV
No picture, only sharp, squeaky noise
Hi, Our TV was working perfectly fine until this morning. I turned it off because I left the house for about an hour. When I returned I tried to turned the TV on but no picture came on only a sharp, squeaky noise that stays on. I can't even use the TV button to turn it off. I had to unplug the TV because of the noise. Please give me some advise.
  • OTILIA GREEN Aug 16, 2006
    Hi
    I still haven't received a reply on this. Please advise.
I'm having the same exact problem with mine! I'm looking for a solution also. I opened up the back of the TV and blew out the dust. Then I checked all connections. I put it back together and plugged it in. Now it doesn't make the high-pitched squeeking sound, but I still don't get a picture. My guess is the picture bulb is burnt out. I'm trying to find one online and am planning to fix it myself - wish me luck!
Posted on Nov 03, 2006
SOURCE:
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Hi-\r\n Thank you for being here- We were watching our Sharp Flat Screened TV, beautiful nice picture. We noticed when we hooked the cable up for Direct TV in our new home, the input connection point was...
With Direct TV, you should use the video input (composite video- yellow/picture, red/right stereo, white/left stereo)
OR
component video- (green/video, blue/video,red/video white/left channel stereo, red/right channel stereo)
the antenna connector should never be used anymore unless connecting an outdoor antenna or VCR.
if one of your input connectors is damaged, it is not likely that is will be repaired without replacing the entire circuit board (expensive!!!).
just use a different "input"- there are usually at least 3 on most TV's
Apr 12, 2011 | Sharp Televison & Video
MY SHARP LCD TV HAS PERFECT SOUND BUT WHEN WE TURN IT ON THERES NO PICTURE JUST RANDOM RED LINES.IF WE TURN IT ON AND OFF THEN THE PICTURE WILL EVENTUALLY RESUME
I don't have a solution, but the same thing happened to ours. To sidestep the problem, I just left it on 24/7. Eventually (three days ago) it just stopped working completely.
Dec 25, 2010 | Sharp LC-32SH12U TV
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
My Sharpe Aquos TV screen stays black even when switched on!
Call up Sharp, if you are part of the AQUOS Advantage Program, you get FREE in home service along with the repairs for it.
They'll give you a case number, set you up with a technician and BAM!
I called on a Wednesday and got an appt for that Saturday for the technician to come to my house.
I doubted Sharp alot less after that.
Aug 28, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Pagnor plasma tv picture problem
hi
i was perchase philips7310 tv toner card in last 2 year back
tha problems is volume is work fine picture is not coming dispaly
plz tel me what is the problem
Jul 10, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Please clarify. Is it your Computer or your Panasonic TV?
Aug 11, 2006 | Panasonic CT-36D32 36" TV
Panasonic CT-36D32 36" TV Logo
144 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
