Question about Garden
NEED A OWNERS MANUAL FOR 1700 ELIMINATOR 17 H.P. BOLENS RIDING MOWER
ENGINE IS MADE BY KOHLER AT 17 HORSEPOWER. SERIAL NO. 14235963 MODEL NO. K717QS SPEC. NO. 24351
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 10865 Answers
SOURCE: I need a Bolens riding lawn mower manual, Do you
here is the link to your manual and all bolens manuals. enjoy.
http://sonnys_bolens.tripod.com/diagrams.htm
Posted on Jul 16, 2009
mowerman1857
  • 389 Answers
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Posted on Oct 04, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
I need to know the specs on an evinrude outboard motor serial # 3030-07926
Everything in marine outboard engines is tied to MAKE and Horsepower. From that, you can find the year using the serial number. Once you have those, you can Google
year make model specs
or
year make model manual
Evinrude Outboard Motor Model Numbers
Jul 30, 2017 | Boating
Model 17 RES spec#GM51561-GAI serial #2234881 - purchased 12-10-08 - the engine loads down and turns off before finished charging - and it does it with breaker on or off and it is intermittent - does not...
If the unit 'loads down" with the breaker off as you indicated, it isn't the load, (unless someone has wired it on the wrong side of the breaker to the home) and is been overloaded. Assuming that is NOT the case you need to check the stator wires to the breaker for ground shorts, especially when the unit warms up. I had a case once where a unit had a bad stator, it would run fine then as it was put under a mild load it would just bog down like overloaded, the stator was heating up and causing a ground fault. Have the unit load bank tested also. I am interested to know what you found?
Sep 22, 2013 | Kohler 17RES 17 kW Generator
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
Need wiring sch for7CCKMR61 spec 140291 serial 326977
I can maybe help with that, as this is an old post, if you still need it let me know
Aug 31, 2012 | Kohler Electrical Supplies
Yes i have a dixie chopper i need to order a part in my town but my # has off of my dixie i have the model # x2303 serial # 7069987 i need the model # and the spec# to order my part i have the engine #...
Your machine came with a Generac engine model gtv760 Spec 005058-X
The engine serial number that you provided belongs to a Kohler Model CV23 Spec 75617
Aug 19, 2011 | Dixie Toys
We are replacing head gaskets on kohler command 25 68500,what are the torque specs for head and intake gaskets?
first torque to 16ft/lbs in a x patt. then 30ft/lbs in a x patt. for head the intake gaskets connecting to the head should be 12 to 17
Feb 02, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Torque specs for 1998 26hp kohler head bolts. aluminum head
I use 150 ft lbs on my racing 2-cycle engines, tighten in a star pattern.
Sep 16, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
What weight oil should I use for 16 horsepower craftsman engine?
It all depends on the engine you have...all engines except for KOHLER can use straight 30 and Kohler uses only 10W30.
May 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
374 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
