Question about Konica Minolta Office Equipment & Supplies
Error code f36 on konica 1212 copier - Konica Minolta Office Equipment & Supplies
Soulvisitor
  • 1113 Answers
SOURCE: Konica photocopier
http://www.copytechnet.com/forums/konica-minolta/5536-need-help-konica-7022-error-f-35-3-a.html
Sorry I dont have axcess to Konica service info but I beleive f36 to be a fuser error, replace fuser and reset switch.
http://www.copytechnet.com/forums/konica-minolta/2704-di620-36-02-fixing-fuser-unit-abnormal-temp.html
Posted on Nov 11, 2007
  • 86 Answers
SOURCE: error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Posted on Feb 19, 2008
Patrillica
  • 141 Answers
SOURCE: Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Posted on Apr 02, 2008
  • 3 Answers
SOURCE: P27 error keeps coming up on a Konica 1212
Run 47 mode output code 51 until the unit does not reoccour may take 5 to 10 attemp,
b. poor conection at cn95, reconnect cn95 located under the front of developer
Posted on Jan 02, 2009
jqsababa967
  • 145 Answers
SOURCE: C-D370 error code for Copier KONICA-MINOLTA C252
this has to do with what they call NAVRAM IS C
To troubleshoot the error:
1. Reset the code by pressing stop-0-7-1-3-9. This will display a "*" on the LCD. Press this button.
2. Perform a Data Clear and then perform the Setup Procedures from the beginning.
3. Perform a NVRAM Recovery Procedure. Please see attached document. To view the PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for free from RRUPTED/need to be reset BUT that will clear all the current setting especially if print to it.if you are willing to try ....
you should have a Tech do this...
good luck
Posted on Sep 20, 2009
Konica 7020 trouble code 36-1
dear need help to resite l detect value auto adjustment developer konica 7020
Feb 26, 2013 | Office Equipment & Supplies
F-36-2
Jeruel:
The Error code F36 indicates an error in the fuser, (the part of the copier that fuses the toner into the paper. Unless you are a copier technician, I would leave this one alone and call for service. An improper repair to the fuser can cause a fire as the fuser works at 375+ degrees. (That's why the copy is hot when it comes out of the machine.
Aug 11, 2012 | Konica Minolta Copier Toner 7033/7040...
F36 reset problem
there is a dip switch that changes state, this is because the machine is in shutdown mode due to a fusing unit error, and must be checked over for possible faults.such codes must only be re-set by a qualified tech....
Jun 29, 2009 | Konica Minolta DiALTA Di200 Copier
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Apr 16, 2009 | Konica Minolta bizhub 180 All-In-One...
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Error code f35-6 on konica 7145 copier
Replace Thermo- fuse (open ) fuser not getting to 160, and clean thermister, toner builds up between roller and thermister causing overheating of fuse to blow .
Apr 25, 2008 | Office Equipment & Supplies
Mar 19, 2008 | Office Equipment & Supplies
Error code 27
thank you
Feb 19, 2008 | Office Equipment & Supplies
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
144 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
