Question about Garmin GPSMAP 188C GPS Receiver
Garmin 188 C chart plotter
I have a 188 c chart plotter that won't read the card upon start up.
SOURCE: raytheon rl70
My 2002 vintage RL70 system had continual "no fix" or "lost fix" messages through 2006 and 2007 seasons. Raymarine rep suggested replacing the 120 GPS receiver with the 125 receiver. I did this past winter and the problem disappeared. The 125 receiver is better technology....not one "lost fix" since replacement.
Posted on Jun 24, 2008
  • 43 Answers
SOURCE: The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Posted on Oct 22, 2009
pabloloco
  • 2335 Answers
SOURCE: GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
Posted on Jan 31, 2010
SOURCE: My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Posted on Apr 28, 2010
Testimonial: "Factory reset solved the problem. Soft key next to power button worked a treat!"
  • 421 Answers
SOURCE: I just bought a boat with a Raymarine C80 chart
Your problem is the 4GB card. The Raymarine C-Series have a problem with their compatability tool and larger CF cards. You should use a card no bigger than 256mb.
The card probably worked in the store because the newer models accept larger cards.
Get an older card from ebay etc and copy your 4gb files onto it and try again. There is more info here: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=1042&p_created=1089743435&p_sid=Y9eWB6ek&p_accessibility=0&p_redirect=&p_lva=1042&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjYsMjYmcF9wcm9kcz0zNiwzNTIsNDEmcF9jYXRzPTAmcF9wdj0zLjQxJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1zaXplIGNhcmQ*&p_li=&p_topview=1
Hope that helps you out.
Posted on Nov 03, 2010
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
Jan 08, 2017 | Raymarine Boating
Why is there a flashing question mark on my gps. and why isn't it locating satlellites.. is it because I don't have a memory card in it.
No it has nothing to do with the memory card. The question mark means it cannot find satellites and it does not know where you are at. Because this is a chart plotter your antenna may have gone bad or the wiring for this device may have gone bad. check the wiring for it here:
http://static.garmincdn.com/pumac/GPSMAP3005C_InstallationInstructions.pdf
Mar 13, 2015 | Garmin GPS
Is their a internal battery in sitex colormax 11
Yes. There is a battery backup to store memory. Read all about the Sitex Colormax chart plotters here:
http://www.si-tex.com/product_manuals/Chart-Plotters-3-08.pdf
Apr 28, 2014 | SI-TEX COLORMAX 11 GPS Receiver
Sep 27, 2009 | Raymarine A65 Combo GPS...
Data cards for Fununo 1850w
Furuno just stopped producing these models about a year ago. They use a special chart card. You can still purchase the cards from Navionics or C-map if you need to. I will tell you from experience that you should get your internal battery changed out if you havent done so already to keep from losing your settings and waypoints. The dealer will have to save them for you though and put them back on. Furuno made a GP7000 to replace this one and it's uses SDcards and is nothing like the rest of Furuno's product line. The best replacement for this unit is the Garmin GPSMAP 700 series. You can use your old furuno transducer if you have one (with an adapter plug). This garmin unit also has a built in GPS or you can use an external one. The 700 series will be shipped in April. Check out Garmin's website or mid-shore electronics.
Aug 29, 2009 | Furuno 1850w/Nt Gps Chartplotter C Map Nt...
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
Garmin chart plotter not booting up.
Hi again,
Appreciate the update. Incidentally, most batteries for this purpose are Lithium 3 volts, coin size. Often, battery removal also performs a reset if not replaced immediately.
Though my money is really on the firmware.
Cheers.
Jun 27, 2008 | Garmin eTrex GPS Receiver
Nuvi 200
Insert your card with your JPEG picture only and you can read it.
You can also plug your usb and go to your computer , open the file GARMIN you will see many files , do not touch the GARMIN main files who include your charts and other important files but the others are there for the users. Copy and paste your picture into the one who already has picture from GARMIN.
Or copy into a SD card and read it on your NUVI 200 or 200W.
Best regards
Jan 04, 2008 | Garmin Nuvi 660 GPS Receiver
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Jul 30, 2007 | Raymarine RL70CRC GPS Receiver
Garmin GPSMAP 188C GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
