Question about Sony KV-27S20 27" TV
Sony 36" tube TV
When I turn the TV on the sound is OK but it does not have video. There is a blank light on one side of the screen, but disappear inmediatelly. Until last week ago I used to fix it and have video just by turning it off, wait some seconds and turn it on again. Some times worked after two or three times turning off, sometimes I had to turn off and on around ten times. I allways had to wait around at least five seconds to have video when working. After the video was on, the TV was fine in general, but sometimes when watching TV the video went off, I tried again by turning it off and come back to normality. All the time and also now the red timer light blinks. In the last weeks the video went off more frequently until it never turn on. I bought the TV aroung 6 years ago and I started to have the problem around 4 years ago. I took it twice to technicians when the video was off more frequently. In both cases they said that they did not find anything wrong, they cleaned, they moved the connections, and the TV started more stable for some weeks. One of them told that I had to change the Tube (??), but I understand the tube is still working , otherwise the video will never work. What do I do? I review the TV and nothing inside looks burned.
    Novelist:
    Champion:
  • 275 Answers
It definitely does not seem to be a problem with the Picture Tube. More like a cold solder. It is definitley not a job for a layman. Also, get a good technician to have a look, as locating cold solders is a labourous and time consuming process. It could also be possible that the main DC filter capacitor is getting dry, and may require replacement.
Posted on Aug 15, 2006
Attempted to turn the tv on, screen stayed blank with no volume either and standby light blinks 16 times.
High voltage is dead,FBT,flyback transformer the cause.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).
Nov 04, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Sony tv
Something is Wrong with the Video.Check Video out,Q705,732,761 and other components on the C board,c also check Q218,219,220 on the A board.In addition,unit could be in IK blanking,try turning up Screen Slightly
Nov 02, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
SONY WEGA 36" TV, BLANK SCREEN NO SOUND
Most commonly, the power supply, and or scan failure causes this. There may be some bad caps, in these areas. In the horizontal output area, the flyback and the horizontal output transistor may also be defective. There may also be some damage to the power supply in this case.
Jerry G.
Apr 19, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
SONY KV-32FX20U
I suspect you crt tube is going and is most likely not worth fixing
There are things you could do a tv service shop could rejuve your picture tube and adjust your screen voltage.
sometimes that does not work
I would start looking for another tv
thanks doctor video
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 36' trinitron no picture but sound
I don't think it's your picture tube, but it may be a problem in your high voltage power supply. If there is no anode voltage then there is no raster (light from the screen) or picture. If it is your high voltage section the you may want to think about taking the set to a shop because of the danger of electrical shock.
Sep 21, 2007 | Sony KV-36XBR400 36" TV
My tv video is turn off but sounds perfect
donot quickly replaced the tube! try this first get 2 megohms 1/2w resistor solder it between blue gun and green gun.if this make the picture still, bad tube.u can still rejuvinate it.if not,bad capacitor in vertical or bad g2(screen) adjuster.
Mar 24, 2007 | Sony KV-27V10 27" TV
Faulty TV
check the ABL at the flyback. sould be at least 185+ volts on the G2 at the crt socket
Sep 04, 2006 | Panasonic CT-36D32 36" TV
Televison & Video Logo
894 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
