I have just put a dvd the wrong way round in my Combo TV and I cannot get it out.
SOURCE: a dvd is stuck in the dvd player of my polaroid
if you will look under the drive where you put the dvd in there is a little pin hole push a small paperclip in there and the dvd will pop out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: Mintek tv/dvd combo dvd is stuck, volume is stuck,
The model DTV-263/265 has this common problem, the main board will have to be replaced.
SOURCE: Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
SOURCE: dvd is stuck in insignia 32inch tv/dvd combo. how
Look at the side where the dvd player to see if it has a small pin hole for inserting a paper clip to eject the disk, if it does not have one then the TV and the DVD transport will have to be disassmbled to get the DVD out. It will not be an easy job so you may want to leave it to the pro to do it.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
SOURCE: the DVD on my Technika
check the fuse inside dvd player your geting power source but your not getin enough it sounds like a blown fuse.
