Question about Exercise & Fitness
Powerjog J100 stops suddenly
Is this type of treadmill affected by low temperatures, ie being situated in a cold garage in winter? I had to warm it up with a heater before it would show the correct display, and then run. When it did run, it occasionally cut out unexpectedly. It had been kept in a warm room in the house previously, without any problems. Or is this a newly-developed fault?
SOURCE: Heater won't start error code 11
I had the same problem and the heater started working after I cleaned both filters, the bigger one that can easily be taken off and the smaller one that needs to be screwed off.
Posted on Jul 15, 2008
SOURCE: Outside temperature reading Jaguar X type 2004
on the jags there is a sensor on the outside by the front bumper cover on the bottom right it sends the signel to the a/c control head panel on the inside of the car you will need to go to a Jag Dealership to buy the sensor..
Posted on Dec 14, 2008
bunnydawg
  • 5158 Answers
SOURCE: 2000 Nissan Altima temperature gauge and heater problem
sounds like you need to replace the thermostat.
Posted on Jan 29, 2009
dsacco86
  • 1077 Answers
SOURCE: Can an LCD tv be kept in the garage without damage?
Well, It depends on the conditions of where you live.
Too much dust and moisture will cause a lot of problems.
Getting too cold will cause moisture to condense.
Getting too hot will cause parts inside not to cool off properly.
The TV should be ok as long as you keep it in a cool, dry place.
Posted on Feb 04, 2009
SOURCE: seat ibiza 1.4 16v 02 plate cutting out at idle
I have the same car and had the same problem, it turned out to be a hole in the vaccume pipe that leads to the engine.
If thats not the reason It may be the ignition coil, which is a common fault in seat ibiza's, this would cost around 75.00GBP to fix.
this site may help www.usedcarexpert.co.uk ,, the site gives good info about all cars and lists common faults and how to fix them.
Hope this helps
Posted on Mar 29, 2009
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Maytag washer will not get warm
1) the temperature coming from your house determine how is the temperature. You can get hot, cold or mix of hot and cold available to your machine.If the water is too cold affect the machine,and if is too hot, the warm temperature colapse.
If you live Northern are, unless you adjust the cold and hot verywell affect the temperatur of your machine.WARM water is better in summer and Colder during the winter.
God bless you
Jun 21, 2012 | Maytag Washing Machines
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
Would like to put older side by side refrigerator in our garage. I was told in the winter, when it gets cold the freezer side will not keep foods frozen. I had an older top freezer refrigerator in the...
It could be a problem depending on how cold your garage gets in the winter. Most refrigerators depend on the compressor turning on to cool the freezer section and that cold air is used to cool the refrigerator section. If your the temperature in your garage gets in the 30-40 degree range in the winter. The compressor may not turn on sufficiently since the refrigerator is typically around the 35-40 degree range. This will cause the freezer to warm up to the fridge temperature and your freezer items will defrost.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have an error message on my powerjog treadmill
jx 100 powerjog displaying self diagnostic error-how do you find what the error is
Mar 22, 2010 | Exercise & Fitness
New Fridge/Freezer placed in Garage,when ambient temp falls freezer stops working
You do not say what type of Fridge/Freezer it is. Some types will not work in cold ambient temperatures, ie unheated garages.
Check the user instructions, if it does not say anything about this, get onto the service department for advice.
Dec 08, 2008 | Refrigerators
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
