Question about Zanussi ZWF1430W Front Load Washer
What does AA40 wash mean?
I was given this machine without any instructions. Please can you tell me what the 40AA cycle means?
5 Suggested Answers
  • 67 Answers
SOURCE: Zanussi ZWD1471W Washer Dryer error codes help please!
http://www.serviceforce.co.uk/pdf_search...
Posted on Nov 21, 2007
SOURCE: what does d3 mean?
it is related to something like cleaning the washer drum.
Posted on Dec 11, 2008
SOURCE: Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
Posted on Jan 23, 2009
SOURCE: ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
I have just moved into an Apartment with a Gorenje wi 62112 Washing machine, I have no manual Can anyone tell me what the numbers on the Dial mean What should I choose for a general wash.
Gorenje has some documentation for their washers here: http://www.gorenje.com/simplicity/en/washing_machines/simple_manual_for_washing . The numbers indicate the water temperature (in Celsius) for a given cycle. The common choices are a cottons load in hot water (60 degrees). This is great for towels and other whites. The mixed load is for permanent press that can be in warm water (40 degrees). Then there is a cold water cycle for delicates (30 degrees). However, you should check the fabric care label before choosing the cycle.
I hope this helps.
Apr 20, 2016 | General Washing Machines
Code 3E displays when I want to start the machine to begin the wash cycle
Please consult the schematic attached to the machine, as it has all the error codes listed on it and it will tell you what it means and how to troubleshoot.
Jan 03, 2016 | Washing Machines
My washing machine is not washing coming up on front display with f_03 can you please tell what this code means please
sorry but we can not assist without at least a make .so search for error codes on Google for it yourself
Aug 17, 2015 | Washing Machines
What does e16 mean please?
An E16 error code means there is a heater insulation problem which could cause the tripping of your fuse box and other random cycle errors, but it's hard to prove without the replacement of your heater.
For more information on other error codes , watch this video .
http://www.espares.co.uk/advice/0/2531/how-to-understand-hoover-and-candy-washing-machine-error-codes
May 15, 2015 | Hoover Washing Machines
Water pump / wont pump out water after wash cycle
The power supply may not properly given to the drain motor from the board please check the voltage at connector of drain if voltages comes then also if it is not working means kindly replace the drain motor
Dec 23, 2009 | Washing Machines
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Need to know what the programme numbers mean please!
Here is the Hoover site where you can download an instruction manual. http://service.hoover.co.uk/manuals/?Section=2 I had no idea Hoover made washers, dryers, or combo units. They only sell vacuums on this side of the pond.
Apr 21, 2009 | Washing Machines
My zanussi 1050 does not stop spinning
hi there aih 1,if in fact you mean the spin cycle does'nt quit when you lift the lid,STOP RIGHT THERE(THIS CAN CAUSE GREAT PERONAL INJURY) if on the other hand you mean it gets to the spin cycle & remains there,it could be anything from the timer,to a relay.in any event without more detailed imfo this all i can tell you.unless you are familiar with working on things of this nature i would suggest you call in a service proffesinal.hope this helps.thanx for using fix-ya & please rate all replys
Nov 14, 2008 | Washing Machines
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Zanussi ZWF1430W Front Load Washer Logo
342 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
