Question about Samsung RV510-A02 T3500 2.10G 320GBDVDRW 15.6IN W7HP - NP-RV510-A02US Hard Drive
Replace DC power jack in Samsung RV510 Laptop
alien_x
  • 281 Answers
SOURCE: i want to no if i can connect my samsung rv510 laptop to my tv through hdmi
No. but you can connect it with the VGA cable
Posted on Dec 14, 2011
SOURCE: how do replace the DC jack on a samsung NP300V5A laptop
DC Power Jacks for the most part are soldered onto the motherboard. There are some models where the DC Power Jack and the cable harness just sits in a slot on the motherboard. And there are some models where the DC Power Jack is soldered on a little circuit board that is secured by screws to hold it into place. In any case to get to the Internal DC Power Jack you have to disassemble the laptop. And if it's soldered onto the motherboard, you will spend time unsoldering the old broken Jack before you can install the new one. Get a quote from a local repair shop, then check the guys out at: http://www.generalsystemsconsulting.com They will repair it and ship it back to you via Fedex or UPS cheaper than most quotes you get including the shipping charge.
Posted on Mar 16, 2012
joecoolvette
  • 5660 Answers
SOURCE: Hey, I have a samsung R60 Plus laptop for a few years now, and its out of warrently and the DC jack power socket has just stopped working. I ordered in a new DC jack for the power socket and soldered
Whew! Not being able to see the motherboard, and damage done, and you need advice?
Okay, onward.
Let's start with some basics first BEFORE you go on.
1) Use a 25 Watt soldering iron, or just stop. Use a No.2 chisel tip.
Use a soldering iron holder with a damp sponge in the base, or have a damp sponge nearby.
(Or use a soldering station)
Keep the tip clean, and well tinned. (Tinned = thin coat of solder)
2) Use .030 Rosin core solder, and Rosin paste. Buy a small brush for the paste.
3) DO NOT linger too long, or you will burn the motherboard, and lift the circuit trace 'hole', right off of the motherboard.
(Crude explanation of a circuit trace, is the thin copper 'wires' on the motherboard)
Lift the circuit trace off, and you will be soldering a jumper wire, (With insulation on it), to an area back on the circuit trace away from the 'hole', and over to one of the DC Power Jack leads. ('Pins')
3) Linger too long on a circuit trace, and it will burn. It will Not accept solder anymore. You cannot tin it.
(Time for the jumper wire again)
4) To remove a DC Power Jack, turn the motherboard upside down. I hold it with one hand. Then use your fingers, and thumb to apply pressure on the jack.
The tips of your fingers, and thumb, act as a fulcrum against the motherboard. While applying steady pressure, (Don't get carried away), apply heat to one of the DC Power Jack leads.
As the lead starts to come out, S-T-O-P
The other leads are still holding the jack to the motherboard.
The procedure is to heat one lead, and pull it slightly out. Then go to another lead near it, apply heat, then pull it slightly out.
Keep going around until all leads of the jack, are free from the motherboard.
HOWEVER, go S-L-O-W. You have all the time in the world. Don't believe me? Mess it up, and you have no place to plug your AC adapter in.
After you heat one lead, and pull it slightly up, allow the motherboard to cool down. (Cool to the touch)
Go to the next lead, heat it up, pull the lead slightly out, let the motherboard cool down.
Once the DC Power Jack is free, there may be a thin skin of solder covering the circuit trace holes, where the leads of the jack was.
This is FINE. Leave them alone.
When you go to install the new DC Power Jack, you will be pressing the leads against the solder covered holes. Touch the tip of the soldering iron against the solder covered hole/s, and the leads will poke through.
Let's look at a DC Power Jack, for a Samsung R60 series of Notebook PC,
http://www.laptopdcjack.net/product_info.php?manufacturers_id=22&products_id=1051&osCsid=n9lotjmn6q04eka4n84gh1htp5
WAIT A MINUTE, this jack connects to a cable. You soldered the leads together, when you were soldering the cable on?
Better take the new DC Power Jack, AND the cable, down to your nearest 'Mom and Pop' computer repair shop, and let them do it.
Cost will probably be a song.
Regards,
joecoolvette
Posted on May 21, 2012
  • 250 Answers
SOURCE: my samsung rv510 laptop has crashed and ive tried to use samsung recovery but its saying operating system not found
Have you deleted or changed settings for the Recovery Partition on your hard drive ?
You should retry Recovery a few times to make sure.
If not, then you will probably have to reinstall your operating system. Before you do, you can remove the harddrive (some models are easy, other require disassembling) and plug it into another computer to extract your data (providing the HD is functional).
If you provide more details on the "crash" or error messages you get on startup, maybe we can get it going without having to reinstall your Operating System.
Posted on Jun 19, 2012
joecoolvette
  • 5660 Answers
SOURCE: no power on my samsung rv510
Zinzee, check the AC adapter first. (Charger)
Wiggle the power cord from AC adapter to surge protector.
See if the AC adapter LED power on light, blinks.
Yes? Bad power cord.
No change?
Go on.
The port on your laptop that the AC adapter plugs into, is the DC Power Jack.
Wiggle the cable from DC Power Jack to AC adapter.
Power On LED light up, or blink?
Change? New AC adapter. (Also need to check DC Power Jack center pin, to ensure problem is cable, not DC Power jack)
No Change?
Go on.
Unplug the AC adapter from the surge protector. You will need a multimeter now.
An economical multimeter can be purchased for as little as $5 to $12. Available at a multitude of stores. An auto parts store is but one example. (Not for $5 probably )
The Function Knob is set to DC Voltage. (DCV)
If just a symbol it is a dotted line over a solid line.
The center hole in the plug of the cable that goes to the DC Power Jack, is the Positive connection. This is where the RED probe lead (Positive), of the multimeter goes to.
The outside cylindrical metal shell of the plug is the Negative connection. This is what the BLACK probe lead (Negative), touches against.
You should read very close to 19 Volts (DC)
Have an assistant wiggle the AC adapter cable to DC Power Jack.
AC adapter is good? No intermittent reading on multimeter?
Go on.
Remove the Battery. Take a No.2 pencil, and use the eraser to GENTLY, see if you can wiggle the center pin around, of the DC Power Jack in the laptop. (DC_IN)
ANY perceptible movement means a problem with the DC Power Jack.
http://www.amazon.com/POWER-SOCKET-CONNECTOR-SAMSUNG-SERIES/dp/B008AGK43O
Chose link for the 4 views of the DC Power Jack.
Underneath the large Main view, there are 4 smaller views. Click on the one all the way to the right.
This is a view of the Back of the DC Power Jack, and the side that faces in on the laptop.
Note the L-shaped prongs on each side of the jack. These go down into the motherboard, and are soldered to the motherboard.
The 3 vertical lugs you see on the back, are the power, and Ground connections for the jack, and are also connected to the motherboard.
1) The center pin of the jack mounts to the jack's body, like a rivet. It is squished on the back, and this holds it in place.
Very easy to break that mount, and loosen the center pin.
2) The connections on the back are soldered, as previously stated, as are the 'L prongs' on the sides. Solder connections are also known as Solder Joints. If the jack moves with the pencil, and it seems to not just be the center pin, one or more of these solder joints could be cracked. (Broken)
Number 1 above means P-r-o-p-e-r-ly removing the DC Power Jack, and properly soldering a new one in.
Number 2 above just means re-soldering cracked solder joints.
DC Power Jack proves to be good?
Go on.
At this point those who use the moniker 'Technician', but in reality aren't a tech, will want to replace the motherboard.
In reality the Power MOSFET's should be checked, to see if they are good.
IMHO a $4 to $5 P.MOSFET (Or two of them), is much cheaper than a $200 motherboard.
Of course if there is $125 to $150 in labor, the savings isn't that great.
Buy an ESD wrist strap, connect it's alligator clip to a good ground source, remove the motherboard, buy the DC Power Jack, and take both to the tech. Should be about $50 labor, or less to replace the Power MOSFET/s. (May not be both of them, just one)
http://www.radioshack.com/product/index.jsp?productId=2103245
[ I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving tray (Unpainted), on the table you are working on, or a large metal knickknack (Unpainted), and connect to it ]
No Zinzee I do not know what manufacturer, and manufacturer number, of P.MOSFET's are used on your Samsung.
I DO KNOW;
1) They us J-leads on the bottom.
Examples,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
http://www.siliconfareast.com/soic.htm
They are located near the DC Power Jack on the motherboard, usually. Example using HP dv6000 and dv9000 series laptops,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Using Fairchild FDS6679 Power MOSFET as an example,
http://www.ic2ic.com/search.jsp?sSearchWord=FDS6679
$2.74 US
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Sep 07, 2012
Samsung rv510
replace the battery as it is not charging.
May 05, 2013 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
No power on my samsung rv510
No change?
Go on.
No Change?
Go on.
Go on.
Go on.
I DO KNOW;
Examples,
$2.74 US
Regards,
joecoolvette
Sep 07, 2012 | Samsung Computers & Internet
Samsung n145 will not power up
Related to a Samsung Np-n145 Notebook PC:
Plug the laptop into power for 24 hours. See if the Battery charges up.
Next test, or have tested, the AC adapter (Charger) See if it is putting out 19 Volts -> DC.
Know someone with a multimeter? I can guide you in testing.
AC adapter is good? Things go downhill rapidly here.
The next problem could be a DC Power Jack.
The DC Power jack is the jack on the laptop, that you plug the AC adapter into,
1) The DC Power jack may be broken
2) The solder joints holding it to the motherboard may be cracked. Poor connection to motherboard.
The DC Power jack can be replaced, or it's solder joints re-soldered.
DC Power jack proves to be okay?
Power MOSFET's have gone bad. The next link, is an article that deals with bad Power MOSFET's in an HP laptop. Used for an example,
Let's hope it's a bad AC adapter
Regards,
joecoolvette
Jul 18, 2012 | Samsung Notebook Np-n145 10.1" Laptop...
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
How do replace the DC jack on a samsung NP300V5A laptop
Mar 16, 2012 | Samsung Computers & Internet
My Q430's power connection is loose and not changing battery. Do I have to swap out motherboard?
The DC Power Jack is the jack you plug the AC adapter (Charger) into. (DC_IN)
The DC Power Jack for the Samsung Q430 series of Notebook PC's, consists of a;
1) DC Power Jack, which is connected to two wires.
2) The wires end in a small male plug connector.
It is now a DC Power Harness,
http://www.laptopjacks.com/part/Samsung-Q430-DC-Power-Jack-J-SM371300C1.html
FOLLOWING Anti-Static Procedures, the laptop is disassembled far enough to unplug the DC Power Harness, and plug a new one in.
Regards,
joecoolvette
Sep 10, 2011 | Samsung Q430 Laptop
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
Samsung r60 plus does not recognise a/c power,i put in the battery which does not charge and it works
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 14, 2010 | Samsung Computers & Internet
Samsung RV510-A02 T3500 2.10G 320GBDVDRW 15.6IN W7HP - NP-RV510-A02US Hard Drive Logo
219 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
