Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Jam 81 showing jam 81 but no paper is jammed
4 Suggested Answers
SOURCE: PAPER JAM
how to fix printer fs-3830n paper jam
Posted on Aug 08, 2008
rajeshpait
  • 542 Answers
SOURCE: how to deal with paper jam when there is no paper trapped/jammed
Check and clean the dust from the paper jam sensor.
Posted on Dec 03, 2009
SOURCE: troubleshooting paper jam
You probably have a small piece of torn paper jammed right up against the paper jam sensor. You'll need to open it up and check the entire paper path for it. Even a small piece of paper can trip the sensor if it's in the right place. If you can't get at the entire paper path, you may need to take the printer to a qualified computer repair shop and have it done. Most shops won't charge you a lot for this job, and it can usually be done while you wait.
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the
Paper-axis System.
Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared
-If this error code appeared but was NOT caused by a paper jam,
replace the Paper-Axis Motor Drive Assembly
Jan 14, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Jul 17, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
MY 81/2X11 inch paper feeds crooked into the printer and jams.
Get a flashlight and look into the printer where the paper enters (Leave it jammed ). If the end, right side moves slower than the left, it is hitting something , check for a paper fragment from a previous jam or other debris. The leading edge of your paper should be touching the debris.
Nov 25, 2010 | Canon PIXMA iP3500 Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Showing as paper jam but no paper jam
Try cleaning the PanaFax UFH585's paper sensor.
Apr 14, 2009 | Computers & Internet
Only 8 1/2 by 14 paper jamming at the DADF
Does it feed sometimes, and just jams frequently, or every single page?
Are you sure the paper size in the tray is set correctly? Otherwise for frequent or constant jams when the paper simply stays in the tray, then the feed rollers are likely worn out.
Mar 16, 2009 | Office Equipment & Supplies
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
PIXMA MP450 alarm light is on and it says paper is jammed but there isnt any jammed, please help?
You could try this, but there is no guarantee. There are a lot of sensor in the paper path of a Canon printer. When these sensors get stuck in the up position, pushed up when paper is present, you get the paper jam alarm when no paper jam is present.
The trick to try that sometimes works is to run some index card stock through. Insert the index card stock in the paper tray, run a print test and as it runs put some gentle firm pressure on the card stock to ensure it travels smoothly. Once it is done the sensor may have reset itself. In lieu of card stock you can use a thick magazine cover and cut it to size of an 81/2 x 11 piece of paper.
If this works great. If it doesn't let me know and please don' t bother to rate this if it fails. It works some of the time and not most of the time.
Thanks,
Worldvet
Nov 20, 2008 | Canon Office Equipment & Supplies
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
27 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
