Question about Cameras
Samsung st65 zoom
My zoom button on this point and shoot has a side-to side play. Zoom function often does not engage when I slide my thumb to operate because button play must cause misalignment internally. To use I have to guide the button into place and usually use two fingers to rotate zoom button properly, impacting the way I'd normally shoot with this type of camera. Anyone else have similar problem or solutions?
jackboy
  • 2985 Answers
SOURCE: Optical viewfinder zoom isn't working
no ideas on how you can get it working. There is I should think a connection adrift. Try the Konica Tech Support Team But be prepared for a zilch answer- I don't think a 'repair' will come into the equation
Posted on Jul 03, 2007
jackboy
  • 2985 Answers
SOURCE: Zoom doesn't work
Digigtal Zoom is simply a method of cropping the image in the camera. The optical Zoon actuates the Lens This seems to have failed Check custpmer support for a repair option Not very hopeful I am afraid - New Camera may be best option
Posted on Aug 01, 2007
jackboy
  • 2985 Answers
SOURCE: IXUS 700 zoom problem
contact customer support If has been dropped a repair price maybe well on the way to replacing the camera
  • 64 Answers
SOURCE: Zoom Control
on the gl2 it is supposed to be slow its not broke theres two switches that can lock the camera and the one by the mic is very slow but ok
Posted on Nov 17, 2007
SOURCE: Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Posted on Jul 03, 2008
What batteries can i use in the samsung af zoom 1050
You will be looking for a 123A battery that you will most likely find at a battery store, or many an electronics store like Best Buy. Or you can google your camera model and order the battery online.
Mar 02, 2015 | Samsung AF Zoom 1050 35mm Point and Shoot...
Lost manual to af zoom 1050
You can use the user manual for this camera that you can download from this link, just click HERE and proceed with the download.
Jul 06, 2011 | Samsung AF Zoom 1050 35mm Point and Shoot...
Xbox picture gets cut off on the sides
try fiddling with the tv menu. most tvs have the zoom function now and also the ratio function. try testing those configurations starting from the default. make sure you have the zoom function set at 0 before fiddling with the ratio aspect.
Aug 14, 2008 | Samsung TX-R3075WH 30" TV
Zoom broke
Solution: Procedure for setting Digital Zoom PowerShot A520
Digital Zoom When the LCD monitor is on, images can be zoomed with the combined optical and digital zoom functions as follows (figures are approximate): 5.7 times, 7.1 times, 8.9 times, 11 times, and 14 times 1. Press the <DISP.> button to turn the LCD monitor on.
2. Turn the shooting mode dial to any Shooting mode except for stitch_assist_icon_a70.gifor movie_icon_a70.gif.
3. In the [ rec_icon.gif(Rec.)] menu, select digital_zoom_icon_a70.gif(Digital Zoom).
digital_zoom_menu.gif 4. Select [On] using the left_arrow.gifor right_arrow.gifbutton and press the <MENU> button.
5. Press the zoom lever toward tele_icon_a70.gifand hold it.
  • The lens will zoom to the maximum optical telephoto setting and stop. Release the lever and press it toward tele_icon_a70.gifagain to further zoom the image digitally.
  • Press the lever toward wide_icon_a70.gifto zoom back out.
digital_zoom_lcd_a70.gif 6. Shoot the image.
  • Shooting procedures are the same as for the auto_mode_icon_a70.gifmode.
  • The digital zoom cannot be used when the LCD monitor is off.
  • images become coarser the more they are digitally zoomed.
  • Since camera shake may become a factor when using the digital zoom, the use of a tripod is recommended.
  • Digital Zoom is disabled when the [Postcard Print Mode] is selected as a image quality setting.
IF this fails, your camera is in need of service.
Dec 30, 2007 | Canon PowerShot A520 Digital Camera
Focus
Your camera has the ability to shoot Macro and Super Macro, although in some Dial Modes, you can't use Macro.
To engage the Macro mode, press once the button on the left side of the lens/camera that looks like a Flower. To engage the Super Macro mode, press and hold the same button for more than one second.
Macro mode range 3.9 in. - 1.6 ft
Super Macro mode range is 0 in. - 3.9 in.
To cancel Macro mode, press the Flower icon button once.
Zoom levels are limited, and you will know that when the zoom bar turns yellow. This means the zoom is not available at that zoom level.
Hope this helps.
Nov 24, 2007 | Canon PowerShot S3 IS Digital Camera
Date stamp
A repair shop or living without it perhaps. check the manual and see if there is a Reset function
May 30, 2007 | Samsung Maxima Zoom 130 35mm Point and...
Cameras Logo
102 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
