Question about Dryers
Maytag lsg7806aa not stopping
Hi, dryer doesn't stop.
changed out timing module ($100). same problem. machine heat-cycles and tumbles correctly. removed motor from timer , and jumpered with 120v. motor works. so it appears that timer module is not getting power to energize timer motor.
is it the circuit board?
there is a thermostat on the exhaust with 4 leads. they alternate with 120v and send power to ignitor when there is a call for heat.
there is another module next to this thermostat (on the exhaust), which has two leads and on the other side is a strip about 1-1/2"long x 1/8". most likely some type of sensor (humidity maybe?).
thanks for your help
coz
  • coz olvera Oct 25, 2008
    there is hot air coming out of the vent. so i would assume that the duct is not clogged.
    Scholar:
  • 136 Answers
If u r unable to know where exactly the problem lies that click on the link below for help regardings step by step check up of ur machine with diagrammatic details:
http://www.applianceaid.com/dryers.html
Posted on Oct 25, 2008
  • 958 Answers
Can you find an electrical diagram in the control panel. you can trace which part controls the timer motor. it could be an interlock in the motor that has no contacts or anything. trace the diagram.
tnx 4 using fixya,
drcool
  • francis rivero Oct 25, 2008
    hi,
    have you found the circuit diagram, if you can post it here then i could help you further which part to check. use the ask me button so that you will not be confused with my answers.
    tnx again,
    drcool
  • Dryers Master
  • 13,433 Answers
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dryer will start to heat but will stop heating after a while but will tumble. Why would it stop heating?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 17, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Hi. Our dryer will start normally and then the
HI. This will occur when the there are issues that concern the integrity of the timer motor. This mechanism is responsible for the rotation of the timer module.It is damaged at this time, and it must be replaced asap.
A damaged timer motor will affect the nature of the drying cycle. It is the main initiator of all functions during the selected cycle.
Oct 29, 2009 | Dryers
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My maytag gas dryer timer does not turn, does not get hot, does not shut off unless I shut it, why?
HI. This will occur when the timer mechanism(timer motor assembly), becomes fused, or the motor itself has failed. The timer mech is the main initiator of all the selected cycles. If the timer is unable to rotate properly, the unit will not heat or stop as well. Replacing this defective timer module will correct this issue.
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer tumbles but not heat
here is the link for the wiring diagram... heat is definatly on a separate circuit.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194
May 25, 2009 | Maytag MDE308DAYW Electric Dryer
Stops heatinng
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat in dryer
make sure the gas is on to the machine and then make sure gas is getting to the machine and then if still not heating check ignitor
Apr 14, 2009 | Maytag SDG3606A Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryers Logo
64 people viewed this question
Top Dryers Experts
