Question about Motorola Radio Communications
Motorola Radius CP200 beeps when bumped
My radio keeps beeping when I bump it on things. Its kind of disruptive being that I work in a school and im in classrooms all the time. How can i fix this. Does it have to do with the battery?
4 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: motorola radius sp50 "roger beep"
The radio will need to be reprogrammed using the radio service software for the SP50 radio.
Posted on Jul 08, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola CP200, radio just beeps when im pressing any button.
It is possible your radio is not programmed, or has a bad/old battery.
It is normal for the side buttons 1 and 2 to beep when depressed to indicate you turned the feature on/off. Each of these buttons has the ability to be programmed a long and a short press feature.
If your radio beeps when your press the PTT button, on any or all channels, it indicates a low or nearly dead battery. Check your battery date code to see if the battery needs replaced.
If your radio emits a long tone on a channel, that channel is not programmed to function.
If your radio beeps a single beep when you turn it on, this is normal.
Charge your radio completely overnight, with the radio turned off. See if this solves the problem. If not, try a new/different battery to see if it will solve the issue. If not, drop by your local dealer and let them look at the unit.
Posted on Dec 16, 2008
eradiostore
  • 1654 Answers
SOURCE: Radius CP200 is in monitor mode I think and i
Your programmable buttons can be programmed to a number of options. Typically the first button is programmed to monitor and sticky monitor. If this button has been held in a long press you can clear the setting by holding it in another long press to shut it off, or by simply shutting the radio off and turning it back on.
Your second programmable button could be set for an number of features, but like the above description, simply pressing it again or shutting off the radio will turn the feature off.
When you refer to Monitor Mode, we assume your are indicating the radio is operating open squelch, with no private line code. This is when you can hear ALL transmissions on your frequency. If this does not describe the problem you are having please repost another question.
Posted on Jul 16, 2009
I have a CP200 that beeps twice at regular intervals, and seek to correct this. It transmits and all, but the beeping is irritating.Suggestions?
It really sounds like a low battery alert. Swap batteries and check the date codes. How long off the charger until you get the beeping? Lithium batteries do not last as long (lifetime) as the older types. Motorola uses 4 numbers, year followed by the week such as 1344 = 2013, 44th week. Chargers are just that and do not test a battery. If the problem persists I have something else, but it is not easy.
Feb 04, 2016 | Motorola CP200 Two Way Radio
How do I get my motorola CP200 radio to stop making an annoying beep every time I transmit
Lincoln-
Motorola Solutions can help you with your radio. You can find their support available at Get Support .
Mark
Motorola Mobility Support
Jan 31, 2015 | Motorola CP200 Two Way Radio
Cp200
can you increase the volume? did you try the morse code button beep beep? are both units on? 10-4 big daddy truck nuts Over and Out
Mar 22, 2014 | Radio Communications
Is Radius cp200 compatable with rdu2080d
If your model number starts with AAH50R... the answer is yes. The CP200 could be programmed to match your RDU.
Jan 30, 2014 | Motorola CP200 Two Way Radio
HEllo, I have a Motorola Radius CP200. When I
If the sound is continuous, like a long tone humming, it is possible you are on a channel which is not programmed. Try changing your channel knob to a different channel and see if the sound changes.
If the sound is not continous, and only happens upon pressing a button, we are not certain what you are experiencing without seeing the radio first hand.
If it were the battery you would get a low battery beep and then the radio would shut itself down. This can happen from a bad battery or a low battery. If this were the situation, you should check your charger and be certain the light comes on and stays on when the radio is placed on the charger. (Note: your radio should always be turned off when on the charger.) A quick test would be to swap the battery with a known good radio and see if you have the same problem. If so, you know it is not a battery or charging problem.
If none of these items help, send or bring the radio to a Motorola repair shop for a quick analysis.
Best regards.
Aug 21, 2013 | Motorola CP200 Two Way Radio
Motorola Radius CP200 flashing yellow when charged
The battery is no longer taking a charge properly and needs to be replaced.
Feb 12, 2013 | Motorola Mint Radius Cp200 Uhf 4ch Radio
Can transmit but not receive, same with or without mic, have tried different mic ...no dice ?
Your radio is in need of repair. Typically you can find flat rate repair for the CP200 style radio for around $85. You may have a bad speaker, or other internal issue.
Best regards.
Jul 14, 2012 | Motorola Mint Radius Cp200 Uhf 4ch Radio
Dec 16, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola radius sp50 "roger beep"
Jul 05, 2008 | Motorola Talkabout FR50 (14 Channels)...
Radio Communications Logo
275 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
