Hotpoint Aquarius WF445 - flashing Pre-Wash constantly
Hi, We inherited a Hotpoint Aquarius WF445 from the previous owner of our house. Therefore, i have no idea how old it is, and don't have any manuals for it.
Recently, it is has started failing to perform a full cycle. If we put it on a preset cycle, it will perform some of the pre-wash, but then will just stick there, and start flashing the "Pre-Wash" light - it will do this until we turn the machine off.
From what I can gather, this might be the filter being blocked, but i can't see where it is. Can anyone help?
Cheers,   Matt
  • fistameeny Oct 26, 2008
    Ok, so i've cleared out the filter (to get to it, turn the machine upside down and it's buried inside a rubber cap that's attached to the drum), but it still flashes "Pre-Wash". Any ideas?
    Matt
  • fistameeny Oct 27, 2008
    Found some more info. The "Pre-Wash" light means that the machine isn't filling with water properly;
    http://www.hotpointservice.co.uk/hs/page...
    The pipes don't seem to be kinked, and the taps are definitely turned on. What else could be causing it?
    Matt
  • 209 Answers
SOURCE: Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Posted on Sep 18, 2007
  • 108 Answers
SOURCE: hotpoint wma 50 flashing pre-wash
Does the machine self turn at all?
Posted on Mar 13, 2008
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
Posted on Sep 13, 2008
i had the same problem, the programmer inside the control panel had blown,
check the wiring hasnt pulled near the motor, sometimes an earth wire comes off apparently.
Posted on Feb 09, 2009
I req the menu list on the powder drawer on the Aquarius wf445 if possible pls regards
Sorry, I don't know your particular machine- is this 'menu' , like on our Bosch, on a card which slides behind the front of the detergent drawer? If, as I suspect, it is then probably your best action is to type into your web browser ' Hotpoint Aquarius WF000 spares' and you should be presented with places which can supply items such as this.
Sorry but this forum does not supply parts direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems ;-0)
Good luck,
John C
Feb 23, 2011 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint wd420. the door light is flashing the wash light is on constant and the machine wont work anyone any solutions please!!
My WD 420 packed up, after watching the blogs I did:1) remove filter - found 2 quid, a thong, a pop sock, a christmas cracker toy and a load of gunge. 2) removed the motor - brushes worn to nothing - replaced them.
Washer running as new. 6 years old, 2 house moves - not bad reliability. Nearly gave up and bought a new machine!!
Nov 11, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint 6kg Aquarius , pre wash keeps flashing, so it is not washing......can you help
Check and clean the pump filter.
Remove lower rear panel of washer, remove large black hose on bottom of drum,remove and clean filter inside, alsr remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 11, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Jan 11, 2009 | Dishwashers
Water is leaking out of bottom of hotpoint aquarius wf445 wash ma
The filter is located behind the removable rear panel of washer.
Remove panel and on the right side you will see a large black hose, undo clip and remove hose, inside you will see the plastic filter, remove and clean.
Be careful, as their will be water run out when you remove hose..
Refit hose and make sure it is on securely..
Check for any leakage before you refit rear panel.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Sep 18, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
