Question about Photography
Olympus om 1 winder fault
Winder advance inactive/stuck
5 Suggested Answers
Gryfox
  • 216 Answers
SOURCE: 67 type II winder problem
This is not a simple repair - if the wind lever is "ratcheting", parts will have to be replaced. If the wind lever is "free-wheeling", there might be no film in the camera, or the counter isn't working ( it has to be at #1 or above to cock the shutter ). It's a job for a repair shop.
Posted on Nov 01, 2006
SGNath
  • 170 Answers
SOURCE: Nikon FE film winder jammed.
Is it the viewfinder or the film advance lever? If the viewfinder is not showing any image and the shutter is not getting released, then it could be a problem with the mirror box.To confirm, remove the lens and see if it gets released. To align the lens, you have to take it to the nearest service center (or repair shop).
Posted on Feb 05, 2009
Obertelli
  • 3006 Answers
SOURCE: Olympus OM-4 stuck shutter
This is very common on many OM SLRs and is caused by dirty shutter magnets. If you look on the web you can find details on how to do this yourself, but as the OM-4 is top of the line I'd highly recommend getting it done professionally as part of a CLA (clean lubricate adjust) service. Last time I had it done in the UK it cost about £80 and when I had it done to my OM-2SP in the USA last year it cost just under $100.
Posted on Jul 26, 2009
SOURCE: Pentax ME Super
i am having the same problem, and the advance lever locks with mine.
Posted on Apr 23, 2010
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Bobbin on Bernina 807 won't wind?
Please follow the logic checks and possible corrections:
1. Check the winder shaft for a sticking or a stuck condition. If stuck or sticking, add a drop or two of mineral spirits to the winder shaft and the winder support bushing. This will generally release the winder shaft.
If the winder shaft becomes free wheeling, clean off excess solvent and apply a drop of Bernina machine oil which is typically a class 68 machine oil. You can also use a common white mineral sewing machine oil.
Do not use WD-40 or 3 in 1 oil!
If WD-40 had been used prior to the winder seizure then you'll know why....Removing sticky WD-40 residues requires further measures.
2. If only the rubber wheel has hardened, you will need to replace the winder hub with a new hub and replaceable winder ring or the entire winder can be replaced. There are some very good after-market parts available online.
3. If the winder parts are good and you are describing a condition where the hand-wheel will not release so that the machine drives while trying to wind a bobbin, this would requite another question and detailed answer... SewTechnical Home
Jan 25, 2015 | Bernina Sewing Machines
Where is the shutter release button on a Canon AE-1? I am trying to load film in the camera, and the shutter crank "thing" is stuck. do i need to release it with a press of a button???
Did you actually mean shutter release or shutter advance? And to load the film,you need to pull the roll winder upwards. While you pull the winder upwards, it would have a tuck voice and then the back cover would open up. Make sure you have wound the entire roll before you open the back.
Jan 23, 2011 | Canon EOS-AE-1 35mm SLR Camera
This is for you camera experts!!! I have an Olympus camera that belonged to my father. The only numbers on it are OM-1n. it is pre digital. I would like to find out more about this camera and possibly...
You can download a manual for the OM-1 from
http://butkus.org/chinon/olympus/olympus_om-1/olympus_om-1.htm
The OM-1MD is the same camera as the OM-1 with the added provision for taking a motor drive to advance the film automatically.
The OM-1n is the same as the OM-1MD with a redesigned film advance lever, a flash ready/sufficient flash LED in the viewfinder, and automatic X-sync regardless of the position of the FP/X switch, when it is used with a T-series flash unit mounted on Flash Shoe 4.
Aug 25, 2010 | Olympus Photography
How do I remove the window winder mechanism on the drivers side door? The window is stuck partly open and I can't seem to move it. Peter
The fault is with the regulator on the window. Remove winder and door handles. Remove door lining and reconnect window to winder rail. Reverse for reassembly
Mar 17, 2010 | 1999 Daewoo Nubira
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
HI i just got a pentax winder me and i put new batts in it and when i turn it on all it wonts to do is keep winding it wont stop it worked one time now it wont stop unlless i turn it off . Thanks James
the winder should stop when the camera counter is on # 1. take the winder off the camera and clean the winder contacts on the bottom of the camera with a pencil eraser. also be sure that the winder is coupling to the advance shaft correctly. not much else you can do as there are no new parts available for this winder.
Oct 08, 2009 | Pentax Photography
AE-1 When I advance the film the winder does not spin.
It is probably that the film in the canister is advancing and once it takes up all the slack in the film canister the film tightens and moves the spindle which then moves the winder.
Mar 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Bobbin winder wont engage properly
Just click below for the guide how to put the needle ;
Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing regards,
Hope it may helps you;
Regards,
VOTIT
Sep 19, 2008 | Singer 3116 Simple
Photography Logo
29 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
