It plays but I don't know how to select a channel to make it show on the tv screen
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
SOURCE: I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
SOURCE: Can you record a playing vhs video to a dvd on sharp dv rw250?
Yes, you can do this if you have a VCR that has a channel on the VHS part of the unit that shows your DVD screen (see instruction manual for better explanation). The Sharp unit that you have might have this feature, if not then look at your instruction manual for how to hook up the VCR part of your unit to an external DVD player. Good luck to you!
