No hdmi on my th-42pw5?
Plasma tv
Agent Aaron
  • 265 Answers
SOURCE: Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
SOURCE: Auto Switch does not work for HDMI inputs
Try this:
http://www.avforums.com/forums/6539544-post3094.html
Posted on May 17, 2009
radar001
  • 1051 Answers
SOURCE: HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Posted on Dec 17, 2009
  • 9 Answers
SOURCE: can i connect my panasonic
Yes you can connect your Panasonic Viera TH-42PX80U Plasma TV to your computer. You will need to buy an hdmi to vga cable in order to connect your vista desktop to your tv.
Posted on Dec 28, 2010
  • 39 Answers
SOURCE: we have connected our asus K52J lap top to our
Hi there
I've just looked at that TV model, and it appears that your TV does not support a separate audio connection for HDMI sockets. It also appears that your laptop model has a issue with sending audio via HDMI. Are you running Linux, or windows?
Hope this helps
TV_Doctor
Posted on Jan 03, 2011
Bought a Panasonic plasma tv. Th-42PW5. Had to run thru VCR due to lack of connections available. Picture is entirely green. What can I do?
sounds like the cable or connections are not good. Your not getting all the signals or the tv needs adjustment/recalibration (if it is good).
does it have a test or demo mode to see if it is good?
some possibly useful links:
. Google
Mar 25, 2017 | Panasonic Televison & Video
Tip
Toshiba 50HP95 Manual Download
Download Toshiba 50HP95 Plasma TV Manual
Would you like to review the features of the Toshiba 50HP95 Plasma TV ?
Have you lost your Toshiba 50HP95 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 50HP95 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 50HP95 Plasma TV documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
Tip
Toshiba 50HP82 Manual Download
Download Toshiba 50HP82 Plasma TV Manual
Would you like to review the features of the Toshiba 50HP82 Plasma TV ?
Have you lost your Toshiba 50HP82 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 50HP82 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 50HP82 Plasma TV documentation.
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP82 50 in. Plasma Television
I purchased a used Panasonic Plasma TV TH-42Pw5. I finally got a picture by hooking it up through a vcr, but the color is completely green. When using the remote instruction colors are varied. HELP!
usually a single color is caused by a bad connection to the display I would guess that a connector inside the TV has come partially loose causing this this is quite common on the computers at my work due to vibration before taking the TV apart I suggest replacing the external cables to the VCR
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
Replacing glass screen on 50in plasma samsung
if your plasma tv is not gurantee and company is not going to repalace it the price of a plasma panel more or less is about 70 %
of a new plasma tv this means that if a plasma tv is 1000 usd you have to pay at least 700 usd
Oct 15, 2014 | Samsung PN42A450 Plasma TV
Problem with the LG 42PC3D 42 in. Plasma Television Horizontal half black screen, sound is still there
Sorry this tv it is not repairable because the tv Plasma screen panel itself it is the tv problems and the causes,this tv only can be repair by replace the whole new tv Plasma screen panel itself only not practical.Because the tv Plasma screen panel are 90% inportant to the tv functions and the cost of the tv.By replacing the tv Plasma screen panel will cost the same as a new tv.
Sep 22, 2011 | LG 42PC3D 42 in. Plasma Television
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
