Question about Samsung HCN653W 65" Rear Projection Television
No audio or video timer light flashes 9 times
It was sudden and unexpected but while watching my TV the screen shrunk and lost convergence. It then bowed out on the left and right sides and shut off. This all happened in about 5 to 10 seconds. I attempted to power it back on with the remote and it came on for about 5 seconds and then off. Since then I cannot get it to come on at all, I can hear the power come to the audio amp but not picture or sound. What typically happens when powered on is the timer light will flash 9 times and then go off. Sometimes it will just come on solid. I have opened it up and looked for anything obvious (burnt wires boards etc.) and none is found also there is no indication of fried components by smell. In fact it is very clean back there. I have been given a possible problem that my convergence chips have failed but it is a big guess from my discription. So I am looking for other guesses and possible solutions short of take it a service center as the closest one is 67 miles away and will not pick up. I purchased the service manual for this unit and attempted to key in the service code in the hopes something might happen. I can see the TV responds to the remote inputs without problem but of course I get no audio or video. It has been over 25 years sinced I messed around in the back of a television so I am definitely out of practice, however I am not afraid to do a little soldering or testing given some places to start. Thanks
  • JOET1971 Feb 29, 2008
    had the same thing happen to my tv. the same tv as yours on the 25th February 08 If you get it to work please let me know what needs to be done. Thank You
2 Suggested Answers
  • 381 Answers
SOURCE: Lights Flashing ???
Check the lamp cover to see if its properly engaging the lamp switch in the down position. You may have to short the switch out altogether. Its a known issue.
Posted on Dec 15, 2009
What could be wrong with my TV? The audio and video suddenly cut out.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 15, 2016 | LG 42" 5400 Series LED HDTV - 42LN5400
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture on screen shrunk to about half size and color bands go around the picture - red, yellow, green, blue - almost looks like things are in 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 22, 2010 | Apex Digital GB43HD09 43" Rear Projection...
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
I have a Sony kp53xbr35 rp tv, the problem is that i turn it on the lights begin to turn on. the screen turns blue to blue green then red and the tv shuts off. i can still get sound but no picture. the...
Projection sets have two very common problems outlined below.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngSOLUTION
Nov 16, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony Trinitron---Blinks 9 times, won't come on!
A specific model number will probably get you more specific
help.. but if you check around the internet by model number
you will likely be presented with some SERIOUS PART opportunities...
The FASHING LIGHT means you have a hard fault in the power circuits...
The number of flashes is mean to point you to a specific area...
I gave all my big flat screens away in favor of the new
HD stuff... (certainly less reliable than those Sony sers...
Shopjimmy might be a great place to call... but the MODEL NUMBER is a MUST.
TV Parts Universal TV Stands DLP Chips ShopJimmy
May 18, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stand-by light flashes 4 times and blank screen/no vid or aud
replace q502 a T504
H.O.T/ and flyback.
parts cost and labor should be about $190
Jan 07, 2009 | Sony KP-61V80 TV
No picture on a Sony KV-32V65 TV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking.
Jan 18, 2007 | Sony KV-32V65 TV
Samsung HCN653W 65" Rear Projection Television Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
