Question about GE Refrigerators
FF diverter airflow Arctica Custom Cool
We were sent a FF diverter airflow for out side by side Arctica Custom cool refrigerator and it came off. I need help with how to put it back on
SOURCE: Refrigerator freezes up
turn off
take all food out.
open door of freezer.
let all ice melt away.
remove cover over evaporator coil.
turn on.
should hear fan running.
if it doesn't, hot wire it with 110 v.
if fan no works with hotwire, replace fan.
if fan works with hot wire, find evaporator thermostat about 1 inch big
clipped on coil of evaporator.  short out ( put wire connecting its two wires ) .
if fan runs now, replace evaporator thermostat about $ 15
Posted on Oct 23, 2007
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
SOURCE: GE refrigerator side by side-6yrs old
I had this problem...my frige is gss20iejp and it was the defrost heater. Very easy to replace yourself if you're good with a screwdriver. Repair guy wanted 200 bucks. I fixed it myself for 40, but still had to pay the guy 30 bucks to come out. You have to remove everything from your freezer, shelves, etc...
Then take off the back panel.
Coils should be completely frosted up.
Defrost heater is at the bottom. It is metal. Should have 2 screws to remove and Conected by wires on either side, they pull out from the bottom, just tug them. Replace with new defrost heater...your problem will be solved.
If you have any more questions, email me jcoverload@yahoo.com and I'll be glad to help you out. I know how frustrating it can be if you don't have the funds to pay the repair guy and know you can fix it yourself with just a little advice. :)
Posted on May 05, 2009
aasc
  • 1606 Answers
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
Posted on Jul 21, 2009
mgprice
  • 744 Answers
SOURCE: freezer cool fridge not
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! Mike
Posted on Jul 24, 2009
Freezer not cool enough
try turning down the thermostat it should cool down then if not check the thermostat is working as it should if its not then change this part,,,
Aug 14, 2010 | GE Profile Arctica 25.4 Cubic Feet...
My Samsoung Refrigerator not cooling on the FF side but
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 09, 2010 | Refrigerators
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
My GE Model PSS25MGNAWW Artica Profile Refridgerator has begun freezing the contents of the bottom Sealed Pan and Fresh Produce Drawers. Put setting up to 2 and Chill Dial to Cold (left) but temp is stayng...
Freezing in cripsersG.E artica:
Models Affected: All 23 25 27 and 29 cubic foot electronic side-by-side refrigerator units with plastic Liners manufactured in 2001 or later. This includes all Profile- (Arctica and Eterna") models Consumers have called with reports of freezing in the Vegetable (middle) pan or the CustomCool M (bottom) pan , frozen water tank or frozen water filter.Freezing in the pans , a frozen water tank or a frozen water filter is caused by excessive airflow from the vents in the tower.
To eliminate these freezing issues , install kit WR49X10045. Follow the instructions included in the kit.
Damper door broken G.E artica:
Affects all 2001 models produced with "M" as the eight letters in the model i.e.: PSS25SGM with serial date code LA4 , MA4 , RA4 , SA4 , TA4 , VA4 , ZA4 & AD4. Freezing happens when damper door breaks leaving the unit with no control over the very cold air entering fresh food compartment from the freezer.
Replace damper door assy , with new damper door kit WR17X11508.
To verify the damper door is broken , remove the light shield and rear light bulb from the top of the refrigerator. Enter the factory diagnostic mode by pushing all four temperature control buttons at the same time. Perform damper motor test (FZ 1 , FF 0). Press any other button i.e. Custom cool or filter reset to start damper test cycle. Shine flashlight through right hand side opening of light assembly to view movement of damper door. To exit test mode (FZ 1 , FF 6). lf damper door assembly needs to be replaced , pull top two shelves out 2 ". Pull rear tower assembly slightly forward with both hands, move to the left and the right to expose the two screws that secure the duct assembly , also remove both screws that secure the duct to the ceiling. Replace with new damper motor assembly WR17X11508.
Dec 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not freezing or cooling
You will need to remove the cover in the freezer section, if the fan is not turning, you will have to replace the fan motor, this what allows the cool air to circulate and cool the refrigerator.
Nov 10, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Feb 17, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigerator side too warm
SHOULD HAVE A AIR DIVERT ER CONTROL TO SEND MORE AIR TO FREEZER AND LESS TO FRIG SIDE TRY TO SENT MORE AIR TO FREEZER SIDE AND LEAVE COLD CONTROL COLD ENOUGH TO ACCOMMODATE THE FREEZER SIDE TO BE COLD ENOUGH
Jan 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Freezing food in upper chill drawer and freezes water in tank
Does you appliance have the custom cool controls ? If it does then there is another air damper in the custom cool unit at the bottom of the fridge compartment
Aug 28, 2008 | GE PSS25NGM Side by Side Refrigerator
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
