Question about Daewoo DVG-3000N DVD Player
DVG 3000N - No display, Not working
I am using DVG 3000N for the last two years. All of a sudden, DVD player stopped working. When powered on, the LED glows, the display light comes on, but nothing else works. In fact, one of my DVD is still inside the tray and the tray is not opening either. The player does not have any front panel lock keys (neither in the panel nor in the remote). Awaiting solutions.
snakehead
  • 1074 Answers
SOURCE: my Daewoo dvg-9200 dvd player wont turn on
take it to a tech the problem is in the power supply.good luck.
Posted on May 18, 2007
SOURCE: Daewoo DF4700P
Model No DF 4700P
Posted on Jan 02, 2008
SOURCE: Daewoo DVD player Dvg 8300se
I have same Modell....u need to change the PAL/NTSC on your TV set...as far as i know DVD output is only NTSC and can not be changed on Player itself.
Posted on Jun 25, 2008
SOURCE: Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
We just unplugged our sony dvd player and plugged it back in and it worked.
Posted on Oct 14, 2009
lscf150
  • 443 Answers
SOURCE: I LOST THE REMOTE TO THE DVD PLAYER. HOW CAN I GET
You would be better off to purchase a unversal remote,it will be less expensive than trying to get the original Daewoo remote,just make sure the remote you select lists Daewoo as one of the manufacturers that it can be coded to operate.This will be a simple process. Good luck!
Posted on Nov 26, 2009
I have a Daewood DVG-9100N/DVG-9200N DVD player. I need a replacement remote. Where can I get one and how do I go about it? Please let me know. Thanks. Patricia DeMarco
It depends a little on where you are in the world. I have found a contact form for the UK (their remote control model list does not feature the DVG-9100N / DVG-9200N, so you would need to enquire with them). The contact URL is as follows:
http://www.4daewoo.co.uk/cgi-bin/pne.pl?display=entry&brand_id=958&f-10=
This will be no good to you if you are outside the UK though, sorry.
Jul 22, 2011 | Daewoo DVG-9200N DVD Player
Need the code for my comcast remote
Depending on which remote you have, you can get the manual at this link:http://www.comcast.com/corporate/customers/customer_support/remotes.html?INTCMP=ILCCOMCOMAL20642&fss=codes%20for%20remote%20control%20
Aug 07, 2010 | Daewoo DVG-3000N DVD Player
BELT BROKE ON MODEL DVG 3000N. THIS IS A SMALL RUBBER BELT THE DIAMETER IS APPROX 1-1/4 INCHES. HOW DO YOU REPLACE THE BELT
Just replaced another DVD player,it very cheap these day.It about $40 u could buy a new dvd player.
Mar 14, 2010 | Daewoo DVG-3000N DVD Player
Can i make it region free?
HELLO
Turn on your DVD Player
Press OPEN on remote
Press 1 3 7 9 and the number of the region you want to use between 0 and 6. Use 0 for region free. You may need to press these buttons slowly. You will see XXXX on the TV. When you press the last number, it will display at the top left of the screen.
Now insert a disc (other than your own region) into the player and close it. It should load and play. Other region discs should play as well. If you didn't do it correctly it will display "Wrong Region".
When you turn off the DVD player it will keep the settings.
HOPE THIS HELPS ENJOY (:-)
Oct 11, 2009 | Daewoo DVG-9100N
Daewoo R-25D06 PREV CH not working
The substitute remote control is not an exact equivalent.
Sep 26, 2017 | Daewoo DVG-3000N DVD Player
My Daewoo dvg-5000n will not recognize dvds
Basically you have two options, as there are many things that can malfunction or become damaged. Rendering it usually un fixable...
Cheap solution
Buy a laser cleaning disc, extremely cheap sold almost anywhere that says electronics. Use the disc in the DVD player.
Expensive
Buy a new one unfortunately, as the repair cost would run you as much as a new DVD player.
Sorry for your misfortune, and don't feel bad I bought a very nice one and it crapped out on me in less than 6 months. Bought a very cheap one and its lasted me the last 2 years and still going strong.
Mar 24, 2009 | Daewoo DVG-5000N DVD Player
I desperately need a code to program my universal remote to my dvd player!
From http://kbase.x10.com/wiki/Universal_Remote_Code_List
004 005 009 017 018 019 042 058 082 083 085 097 100 126 127 130 138
It is one of these codes listed above.
Jan 24, 2009 | Daewoo DVG-3000N DVD Player
Daewoo dvg3000N
If the noise is coming from the speakers rather than the unit itself, the d-A converter for the audio path is defective and should be replaced, This is most likely a surface mounted IC and should be replaced by a service shop. Expect a parts cost in the $25-$35 range.
Dan
Nov 28, 2008 | Daewoo DVG-3000N DVD Player
Not turning on dvd
maybe you have primary power supply problem! check the fuse! then next check the un regulated power supply if passing... then next check the regulator.
Oct 07, 2007 | Daewoo DVG-8500N DVD Player
My Daewoo dvg-9200 dvd player wont turn on
May 18, 2007 | Daewoo DVG-9200N DVD Player
Daewoo DVG-3000N DVD Player Logo
37 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
