Question about Kenmore Elite HE4 Electric Dryer
Kenmore 110.82832100 turns on and clicks but will not start
Starts program and cyles through but does not run
3 Suggested Answers
jonniewalker
  • 1031 Answers
SOURCE: dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Posted on Feb 05, 2009
heatman101
  • 43501 Answers
SOURCE: you have answered this question
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Aug 10, 2011
Kenmore classic dishwasher washing cyle doesn't start
It sounds as if you need to replace the timer. The reset motor is separate from the primary motor--that is why one type of "cycle"--diagnostic-- seems to work but the regular cycle(s) do not.
Jan 30, 2013 | Dishwashers
Once dishwasher starts wash cyle, it keeps running wash cyle indefinitely. what do i need to do
Possible that the diswasher control panel is not in order and is a suspect. remove power for some to reset the board. Try with different program and if the same action continues check with the panel board before you can think of swapping to confirm the case.
Jun 28, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Neptune dryer runs then shutsoff then starts again
probably bad computer board expensive repair hope you love the machine
Mar 30, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Turn washer to normal or gentle cycle water will
add a pail of water if it starts adjust level control
Aug 11, 2009 | Washing Machines
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore Oasis Spin Cyle Extremely Loud
Your probably right as most washing machines use bearings and they do wear out rather quickly on some machines ,depending on how yours was put together will determine on how easy it is to change , some manufactures made it much more easy than others .If you remove the back panel (that's if it has one )and after it has gone through its spin cycle and you have turned of the power you should be able to feel around where the bearing is incased to see if it has generated an amount of heat even though they are usually encased in oil as this would be a indication that it has failed, if you watch the machine clicking into spin mode ( by looking at the motor etc with the back cover removed)you will also get a better idea as to what parts have come into play and pinpoint the problem area .
Aug 07, 2017 | Kenmore 27032
Kenmore Elite HE4t Washer
remove bottom panel pump is slightly right of center in white housing the is a knob turn counter clockwise ckd for anything that may be blocking pump or has pump impeller locked be sure to ck as far as possible into pump throat if impeller is locked pump can be removed and taken apart just remove hoses and power plug take pump completely out and remove screws around edge reverse procedure when reinstalling just be sure large o ring is reinstalled properly
Jun 09, 2008 | Kenmore 45081 Front Load Washer / Dryer
Error code F02 f the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the ?Sud? error will be displayed, then 4 minutes later the F02 error code will be displayed. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check the electrical connections at the pump and make sure the pump is running. ? Check the drain pump filter for foreign objects ? If the above does not correct the problem replace the pump
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He 4t washer
washer weary, You need to clean the filter on the pump. Remove the bottom panel and the filter will be right in front. 3 #11 torx screws it will pull down and off. Get yourself a bucket to catch the excess water. Unscrew the filter and clean it. Check to see that nothing is in the impeller. The F02 should go away..Catriver.
Kenmore Elite HE4 Electric Dryer Logo
24 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
