Question about Olympus Audio Players & Recorders
Olympus SRS WOW XT stopping fast play
When I record, it is fast play. How do I change that?
3 Suggested Answers
fixlover21
  • 9 Answers
SOURCE: recover deleted files from olympus recorder srs
Digital Voice Recorder Recovery is such program that will help. It is able to recover AUDIO file (MP3, WAV, WMA, OGG, AAC, AIF, M4A, MID), photos and video files deleted, formatted or lost from mass storage media including common digital voice recorder such as Sony ICD PX 312, Zoom H4n, Olympus VN series etc. Take the trial version first, it's FREE!
Posted on Aug 03, 2011
  • 57 Answers
Yes, it's possible to recover files removed from myrecorder device. The best way is to use a file recovery software, recommended asoftech data recovery as it helped me before. use link below to download the software
Data Recovery Software for voice recorder
Here's a step by step guide that I find very useful
How to get back files from USB drive
Here's a video tutorial that you may take a look
Posted on Feb 22, 2013
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
Firrst what is an srs WOW mode i downloaded songs and they only play 4 10 secs and then another song starts and it does the same thing?
what is the motherboard? also it sounds like its set up on like auto scan each song for a few seconds then change.
srs wow mode imakes it sound lik a virtual surround sound systm i would disable that and try the songs again. also try using winamp instead of itunes or windows media
Mar 17, 2011 | Computers & Internet
Recover deleted files from olympus recorder srs wow xt
Nov 13, 2010 | Olympus Audio Players & Recorders
My screen broke and I am unable to change my settings. Is there any way ui can get a picture of the mode settings?
holding the MODE button will return you to the main screen. They are Music-Movie-Picture-Setting. You should be on the Music screen first. Pressing down will take you through these in order. Under Setting is LCD set, Language, online device, memory info, firmware, remove mtp info, default, exit.
While in Music (as long as you are not playing a song) tapping the MODE button will give you the option of going to the local folder or exit.
If you play a song and press MODE you are given the following options Play Mode, Equalizer, SRS WOW Mode, and exit.
Under Play mode are the options, Normal, repeat one, folder, repeat folder, repeat all, random, and intro.
Under Equalizer is flat, rock, pop, classic, soft, jazz, DBB
Under RS WOW mode is srswow, user setting, disable srs wow and exit.
I hope this is what you were looking for.
Jun 26, 2010 | GPX ML648B MP3 Player
My Olympus Pearlcorder J300 plays the tape back too fast
Hello check the switch for VOX needs to be in the middle position make sure is not on F.Play
If the speed doesn’t change is your main motor
Apr 03, 2009 | Olympus Pearlcorder J300 Handheld Cassette...
Sound blaster conflict
Wow I have an audigy card and a Olympus and never had that problem before.
Goto soundblaster.com and make sure the audigy drivers are updated. There is an update to the olympus software available on their website as well.
If the volume is up too high on your recorder when it is playing back, it may shut the speakers down as a safety precaution especially if your sound card has a limiter to it.
May 22, 2008 | Olympus DS-30 Digital Voice Recorder
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
