Question about Indesit W 123 Front Load Washer
Indesit Wg1130T My machine wont always drain and spin,do you know whats wrong with this?
  • Fabby19 Nov 03, 2008
    Thanks changed the drain pump and cleaned the manky hose, works a treat. Lets hope it lasts another 11 years, ha ha. Thanks again.
DRAIN PUMP BLOCKED OR FAULTY
Posted on Oct 25, 2008
Wont rinse or spin
I think your washer's drive belt has broken, Joanne. You'll need to have someone replace it. That's a pretty easy fix, but they'll need to know your washer's model number before they arrive so they can bring the correct belt to fit it.
Aug 06, 2014 | Indesit Washing Machines
What are the official dimensions of an indesit wg1130t
These are the official manufacturer specified dimensions for the WG1130T
width 59.5cm / 595mm / 23.42 inches
height cm 85cm / 850mm / 33.46 inches
depth (front to wall) 55cm / 550mm / 21.65 inches
If you need any further specicications, please post back or download the full user manual from here:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WG1030G_WG1130TG_WG1230G_19502233000.pdf
Regards,
BElectric
Nov 28, 2010 | Indesit W 123 Front Load Washer
WASHING MACHINE WONT DRAIN OR SPIN
did you get a solution as i now have this problem
Jun 08, 2010 | Washing Machines
My machine wont drain the water or go to the spin
Drain Vlve command no activated. Or The valve is faulty. Check wiring also.
Mar 28, 2010 | Indesit W 123 Front Load Washer
Indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Aug 04, 2009 | Indesit W 123 Front Load Washer
Indest wil103 has 3 flashing lights the power one and to green ones stain remover and extra rinse and want spin what is wrong please help
If the machin isnt able to evac the water, it wont spin. It will indicate error with 2 flashing lights + lock led. Check pump, drain hose.
Jul 26, 2009 | Indesit W 123 Front Load Washer
Washing machine wont spin
Your machine may not be receiving adequate voltage to start. Make sure your machine is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your machine. Also, refrain from using an extension cord to plug your machine in.
Dec 03, 2008 | Indesit W 123 Front Load Washer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
327 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
