Question about Miele W2662WPS Front Load Washer
Door seal for miele w2662
Where can i buy one from at the best price and are they difficult to fit
5 Suggested Answers
  • 1462 Answers
SOURCE: I have a miele w2888wps
i think you maen the outer door clamp - the one that holds seal to cabinet
it just tucks into a groove in the seal with the spring at the bottom
Posted on Sep 11, 2008
reverendrave
  • 24 Answers
SOURCE: replace door seal miele novotonic w 502
Hello mc2739,
It's been awhile for me since I have done this so I searched on the internet and found the following. The instructions are pretty detailed. You may want to contact Miele if any problems
1. Open the machine door.
2. Turn the main power off and unplug the machine from the wall.
3. Completely remove the powder dispenser drawer (it will come out so far (and stop), then there is a small button at the rear of the dispenser which you need to depress to remove it fully, you'll see this button once you've withdrawn the drawer to its stop position.
5. Undo and remove the 3 x hexagonal head bolts surrounding the door seal (they are at approximately the 2, 6 and 10 o'clock positions). Note these bolts actually secure the front panel to the machine chassis, they do not retain the door seal. Don't worry the front will not drop off.
6. Now look at the aperture of the powder dispenser drawer (you have of course removed the actual drawer earlier). Locate the lower left hand corner of the aperture, and you'll see a recessed philips head screw in a hole. Undo and remove that screw.
7. Now, you'll need to get on your hands and knees. You DO NOT need to tilt, or lift up the washing machine to do the next bit. Locate the underside of the front panel right at the bottom. You'll notice that it sticks out about half an inch or so and is proud of what I would call the kick plate which extends right down to the floor. You need to look on the underside of the front panel, about an inch or so in from the left hand edge. There you will see a spring loaded clip which when closed is located within a slot on the underside of the front panel. Using a flat bladed screwdriver, you need to carefully lever the spring clip open whilst gently pulling the whole front panel (from the left side) ajar. It will just suddenly pop out once you've done it.
8. Open the pump access door lower left hand side of the front panel) and unclip the drain tube from its plastic retaining clip.
9. Now carefully swing open the whole front panel, it opens like a door (hinged on the right hand side). It might be a little stiff as there are a whost of leads attached to it, but it is designed to open fully (with the leads attached) to about 90 degrees.
10. Next, unseat the rubber door seal from around the door opening area (on the chassis, not the front panel, obvioulsy), so that the seal the flops away from the chassis and lies just inside the machine.
11. You will notice that there is a thin steel band holding the door seal in place around the drum. On the right hand side (at about the 3 o'clock position), you'ss see a tensioning screw for the band. With a flat bladed screwdriver undo this completely and remove the screw (it is accessible from above with a long screwdriver). Be aware that there is 1 x washer and 1 x 'nut' type fitting that will fall out when you remove the screw. Locate these and retain them for later.
12. Now extend the steel band to its maximum opening (by moving the 2 x lugs apart where the now removed screw was).
13. You can now remove the steel band. Then pull it out through the hole/door aperture in the chassis.
14. Locate the small rubber tag at about the 12 o'clock position where the seal is attached to the drum and tug it. The seal will then come away from the drum. Remove the old seal completely.
15. Using your new seal, place this correctly around the drum (there is a lip on the seal and this has to go over the lip on the drum. Remember, the seal goes on the OUTSIDE of the drum. Ensure the 'tag' is at the 12 o'clock position.
16. Reassembly is then the reverse of removal.
17. Make sure that you do up the retaining steel band sufficiently and that you correctly locate the sela on the chassis front panel (there is a groove in the seal which will locate the seal in the aperture).
18. Finally, once you're done, put the machine through a few rinse cycles (where the water level is high) and look for leaks. If you have a leak, it is likely that your door seal has a rip/tear, or that it has not been correctly located around the drum - in which case you'll need to investigate.
Posted on Sep 17, 2009
  • 177 Answers
SOURCE: where can i buy a new door seal/gasket for a miele
only can be purchased through Miele spare parts or a service agent of Miele.
Posted on Jan 18, 2010
  • 70 Answers
SOURCE: miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Posted on Jul 08, 2010
I am looking for a new door seal for my Miele washing machine. its a brilliant machine but is leaking badly now. model W1712. your assistance in finding one for me would be very much appreciated.
Hi.
Miele make an excellent machine and I would advise you to have the door seal replaced by an experienced technician. The job is not as straightforward as it might appear.
I suggest you contact 2 or 3 repair people and check prices. Try to get some idea of the final price because the labour cost can be open ended and a big surprise...
I generally allow around an hour for a door seal replacement. It can take longer.
Good luck,
Nomess
Mar 03, 2015 | Miele Washing Machines
Door on my miele built in dishwasher is broken
First thing you need to do is SEARCH for "spares"
for your Miele G685sc
We don't seem to have "parts" for your G685sc here
in the USA...
but a casual look over BOSCH hinge and spring costs
show the hinge at $20 USD
AND
SPRING at $10 to $19 US Dollars...
Lower door gasket $20 to $30 USD
AT those prices I would attempt to avoid a "new"
dishwasher... When you are done trying to get a HEATER,
silence and stainless interior...
You are looking at BIG MONEY.
Check the FIT of the door... and health of the gasket(s)....
I'm just saying... I would
(it is the ULTIMATE in recycling).
http://www.appliancepartspros.com/bosch-dishwasher-gasket-seal.html
Apr 11, 2017 | Dishwashers
Where can I buy Caroma outlet seals?
Take the existing part to Lowes or Home Depot and look at there universal
toilet replacement parts. I bet you can find one that will fit.
Jan 04, 2013 | Caroma CARAVELLE270ADAW-EL Caravelle...
I would like to get some information on how to replace the door seal of a Miele Metor 4000?
Depends if washer drier or just washer...The Door boot seal is secured with two rings one on the outside of machine case the other on the inside...The tricky part is fitting the inner ring in some cases the front of the machine can be removed,greatly simplifing the job if you look on utube you will see step to step how to fit a door boot seal this may help you decide if you need an engineer to do job..Happy New year from Scotland...
Jan 01, 2011 | Miele W 4800 Front Load Washer
IS IT EASY TO REPLACE THE DOOR SEAL/GASKET ON ZWF1430W
it is very very difficult to replace the door seal on a zanussi washing machine, its best fitted by an engineer
Feb 03, 2010 | Zanussi ZWF1430W Front Load Washer
I need to replace the door seal on my Miele refrigerator
You can open the door, pry off old seal with screw driver,
Then line up new seal. After it is lined up, then you can use sealent inside the seal, and place on the door. You should need to take door apart, though you may need to remove it from the hinges. There are many youtube videos and howstuffworks.com videos you can view that will show you how this is done.
Sep 04, 2009 | Miele K8952SDED Refrigerator
I have a miele w2888wps washing machine and the wire with the spring attached has come off therubber door seal. I would like to see a diagram that shows where / how it fits back on
Sep 11, 2008 | Miele Washing Machines
Parts
You could buy a no name door seal gasket from any dishwasher parts supplier but you will loose your warranty with Miele. And extended warranties reach up to 6 years if you bought it from a factory authorzed dealer with a factory authorized installion! Call Miele direct. Miele's number is 1-800-843-7231
If you would rather call your local Miele dealer, they'll be more than happy to do help you!
Oct 13, 2007 | Miele 23 in. Novotronic G841 Built-In...
Candy washing machine
door seal replacement can be done with a little skill and a bit of common sense, 1st thing to do is buy a replacement quoting make model etc, then you will see how the seal is shaped to fit, unplug the machine and work from the front, open the door and remove the thin wire clamp from round the edge of the door seal, remove from the lip of the cabinet and that will enable you to see inside the casing, there is a wire spring or an adjuster on the drum end of the door seal, remove that and the seal will pull off with a gentle pull, refit as removed, take note how you removed wire etc, check for leaks and state of fit before leaving machine unattended and running difficult job hard to describe in writing, but not too hard with a little thought
Sep 17, 2007 | Washing Machines
Miele W2662WPS Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
