Mig Welder problem
SIP 180 mig welder has suddenly stopped arcing and acts as if the earth is not attatched. Feed is running ok and all mechanical and cooling fan making the right noises.
  • nirvanalin Apr 19, 2009
    I used the mig the previous day with no problems. Turned it on the next day and every thing seemed ok ( wire feed and fans running ) but could not get an arc.
    Problem Solver:
  • 6 Answers
Has the duty cycle been exceded? if so the control chip will shut it off.
Posted on Oct 25, 2008
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
The Mars 180 MIG Welder Manual neglects to
Hi mate. Not sure on the power settings but the earth clamp is negative for gasless and possitive when useing gas
Mar 20, 2010 | Welding Tools
I have a speedline 180 amp arc welder and it doesn't want to arc i turn welder on it makes the nose its spose to make and i connect my earth go to strike and nothing happens? any ideas??
Check for output voltage (ac or DC depending on model).No voltage,welder has a problem.
You must have a clean ground clamp attached to bare metal with some welders to make them work.
Sep 08, 2009 | ARC Welding Tools
Wire won't feed into hose adapter.
You will have to adjust the tension at the feed wheels, also make sure the spool is not too tight, I had the same trouble with the 180 model, just a bit of fine adjustment
Aug 02, 2009 | Hobart Handler 140 Mig Welder
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
