Question about Cooktops
I have a Zanussi Hob Zic B750 which suddenly stopped with the breaker tripped. After resetting the breaker the supply is coming to the switch but the hob does not come on. Connections at the switch se
Zanussi Model Zic B750 induction hob
  • 1462 Answers
SOURCE: Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Posted on Aug 28, 2008
SOURCE: Neff T4344 hob, need instruction manual???
Try http://bshappliancecare.com/Neff/customercare.html
You can download a PDF manual for the T4344
Regards
Jon Morgan
Posted on Feb 06, 2009
  • 63 Answers
SOURCE: Burnt induction hob
hi my name is mark, you can try softscrub or a glass cook top cleaner made by jenn- air or a genaric brand from the supermarket.
Posted on Mar 10, 2009
SOURCE: Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Posted on Nov 06, 2009
  • 4 Answers
SOURCE: My Neff induction hob has prgressiely getting
Hi, if you take off the magnetic knob & let it flash a little longer, then switch off & on again it will work. Ours is doing the same. The book says it needs cleaning, as do the customer services people but I've cleaned & cleaned it & I assure you it's spotless. You don't have to wait 10 minutes though to start cooking, just 1 after switching off. It is very annoying though & I think we will be getting an engineer out to look at it.
Posted on Dec 15, 2009
Hotpoint induction hob wont turn on
Check power supply at socket or meter box. Make sure that the circuit breaker hasn't tripped. Also, induction cooktops wont heat without induction cookware. They must be steel. Glass cookware wont work on an induction cooktop.
Jan 03, 2015 | Cooktops
Why is our Logik Lindhob10 not switching on?
Have you tested the fuses with a multimeter? Sometimes they look ok when they,re not. Using the multimeter trace the wiring till you find where it stops, it may be a fusible link that's encased in a fibreglass sheath. Good luck and be very careful when it's live.
May 14, 2014 | Cooktops
Back L element no go
Feel free to download a copy of your wiring diagram from http://sparepartspro.zendesk.com/entries/118713-zanussi-electric-hob
Qualified Electricains only.
Feb 24, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
All 4 elements suddenly won't heat--worked fine this am. Circuit breaker was tripped. Reset, now lights on knobs come on, but still no heating.
Likely a short in the junction box. Turn off the breaker and open the junction box for inspection. Problem is likely at the cooktop end of the feed from the breaker.
Check voltage at the junction. Should one side of the corcuit be dead, turn off power and call an electrician as the wiring probably has had a short due to staple or nail penetration and would be a fir hazard. Call an electrician if this is the case.
Jan 12, 2010 | Jenn-Air JED8430 Electric Cooktop
SMEG SE435X-1 60CM Electric hob. Keeps tripping fuse
It's possible that one of the burners stay on for a long time, which cause one of the wires to overheat, breaking the connection and touching the body of the unit, please turn the breaker off and check for a loose connection, replace the wiring if you feel confortable doing it yourself or contact a technician.
Jan 06, 2010 | Smeg 23 in. SA435X Electric Cooktop
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Brand new bosch pke691e20e ceramic hob trips 50amp mcb
You have a short to ground somewhere.
Was there a new cord installed on it or did the cord come already installed?
It could have been wired wrong causing a short to ground. there could be another wire touching the cabinet, a wire pinched by the cabinet.
You may have to trace down every wire with a continuity meter to find it, but its probably fairly obviose.
I'd start at the cord.
First try this, unplug the cord, turn the breaker back on just to make sure the problem is indeed in the unit not the receptacle or panel box.
If the breaker stays on, you know its in the unit.
Dec 05, 2008 | Cooktops
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Mar 01, 2008 | Cooktops
Cooktops Logo
122 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
