Back to:
Tags:
Jenn-Air JES9800A Electric Kitchen Range
Function Problem (by 2 users)
posted by Squeaky on Aug 15, 2006
We have a glasstop range and today some water bolied over onto the stove. This has happened before and the water simply stayed there or burned off. Today, the water apparently seeped into the oven are because we received a code (F9 -3) and were instructed on the display to call the service line. We did and they insytructed us to hold down the "cancel" button for 5 seconds or unplug the unit or turn of the power source. We tried the cancel button and shut off electrical power to the range but it did not reset. The "F9-3" code came back and the display continued to instruct us to call service. The stove top works but we are unable to bake or broil. Before we call service, can we do anything else to troupble shoot?
Any advice??
Paul
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by SueBG, posted on Apr 22, 2008
I just wanted to stay we just had the exact same problem and this fix worked perfectly! Thank you for saving us $$$!
Best Solution
posted on Aug 15, 2006
FixYa! (100)
catriver
Rank:Guru Guru
Rating: 94%, 2653 votes
Paul, the F9-3 code has to do with the oven door lock motor assy.. Water must have gotten on to it and now the fault. There is a quick test mode on the model ending in aab, if yours ends in this try this. Unplug the oven for 30 seconds, plug it back in and press and hold the cancel and broil buttons together. It should enter test mode. When in the test mode press the clean button to see if the motor activates and resets. Press cancel to exit the test mode...Catriver...post back
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Function Problem:
I don't want to Accept this solution
Solution #2
posted on May 28, 2008
Not Rated (0)
jerseyjoe7
Rank:Apprentice Apprentice
Rating: 89%, 4 votes
it too seven trys but it worked!I shut off power for a longer time (5 min) did not hit the cancel on the last step...
Thank You!
Can you Help with these Kitchen Ranges problems?
Hi, I have a Jenn Air Electric Stove. Everytime I try to...
Our Jen Air Range has recently developed a peculiar habit....
I need ti know where to put the vents for a microhood and...
Some boiling fruit juice spilled over onto my cooktop, a...
while cooking, slide in stove shut down, beeped...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
