Question about Dell 1600n All-In-One Laser Printer
Dell 1600n pickup roller issues
The pickup roller is not feeding the paper into the printer causing it to have an error.
  • 3 Answers
The1600n pick up roller part number R5375 is probably cracked and otherwise in need of replacement. They cost about $20 - $50 from various sources. Try ebay and Amazon.com first.Dell 1600n pickup roller issues - 8_1_2012_11_46_03_pm.jpg
Posted on Aug 01, 2012
SOURCE: Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Posted on Jun 19, 2008
  • 7 Answers
SOURCE: Dell 1600n printer driver for Windows 2003 Server
I had a similar problem deploying these printers, however i found using the XP drivers in 2003 does work fine. Not sure why dell doesnt have an installer for this printer in 2003 server, but here you go.
ftp://ftp.us.dell.com/printer/R165289.EXE
extract that file, note its destination directory. do not attempt to run the setup.exe, it will fail saying your operating system is not supported.
instead navigate to (if you didnt change the path) C:DelldriversR165289p0nPrinterPCLWINXP
this folder contains the driver you need to install manually.
one stange thing about these lexmark based network printers is the need to select 'local printer' during install, uncheck automatically search for my device, and then create a new TCP/IP port. Use the IP address provided by the network configuration print out you can access on the front panel of the printer. now just make sure to select 'lexmark network card' as the type of network interface. it should now ask you for your printer type, click have disk, and point to the driver folder mentioned earlier.
hope this helps. thanks alot dell.
Posted on Nov 10, 2008
SOURCE: dell 1600N printer paper jam
More than likely you need a new pick up roller. It is located at the top of the tray area in the printer. You will see a black rubber roller with white nylon clips on both sides. You can confirm if it is the problem by removing and washing it with soap and water, then clipping it back in and running a few copies.
Posted on Jan 14, 2009
  • 53 Answers
SOURCE: dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Posted on Apr 27, 2009
SOURCE: I have 2 Dell model 1700n laser printers and they
Take off the two rubber rollers, turn them inside out and replace them, Voila!
Posted on Aug 23, 2009
Error paper jam
Hello Cassandra,
It sounds like you are having phantom paper jams. When the printer starts a print job and tries to pull a piece of paper but can't grab it the printer thinks there is a jam but there really is not. If the paper pickup rollers are worn down they are not able to grab the paper correctly to feed it into the printer which causes this type of error. The rollers are considered user installable and come in a kit with the rollers and the paper separation pad which keeps more than one paper from being pickup up at the same time. Installing the paper feed kit should clear up your paper feed problems. The paper feed kit is available here: http://www.ccl-la.com/catalog/product_info.php?products_id=342
I hope this helps.
BuddyMc
Aug 06, 2013 | HP CP3525N Color LaserJet Printer
Paper does not feed properly, slips, skids
Make sure the paper guides are properly aligned and spaced if they are adjustable.
The pickup roller may be worn out or loaded up with dust. If wiping it with a damp cloth doesn't help, replace it. (I tried rubber conditioner on one once. While the stuff normally works wonders, in this case, it made the pickup roller break out with little flaps of material all over, and it was still useless.)
Normally a problem with a roller farther into the printer causes the paper to crumple up in an accordion fold and jam, so I don't think these need more than a cleaning, and they probably aren't the problem.
It's also possible you have a foreign object in the paper path such as a shred of torn paper, but a good pickup roller would normally jam the paper into it before the printer halts with an error.
Jun 17, 2011 | Dell 926 All-In-One InkJet Printer
My dell mfp 1600n will not feed paper without jamming in the auto feeder...what is wrong?
if the problem is with the paper from tray, suspect the rubber tires on the pick rollers are bad. You can remove them and flip them inside out and reinstall
Dec 31, 2010 | Dell 1600n All-In-One Laser Printer
It say error JAM 1 what does that mean
Look inside printer to see af any paper is in there if so remove.Pull out paper tray and clean pickup roller (roller that picks up paper from tray)if the roller has film on it it will cause jam1 error
Mar 22, 2010 | Dell 1600n All-In-One Laser Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
Where to get fuser and rollers
Sorry it took me so long to get back to you, I've been out of town for a few days.
The parts you need for the 1600n are from Dell.
Part# N5796 - Fuser
Part# M5512 - ADF pickup arm roller
Aug 11, 2008 | Dell 1600n All-In-One Laser Printer
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1700 Transfer Roller
These series printers have a typical problem of the paper pickup rollers wearing out resulting in jams, crooked feeds and partial feeds. a quick fix:
take the paper tray out, turn the printer on edge and locate those two rubber roller bands on the pickup arm. Peel them off, flip them inside-out and return them to the rollers. This restores thier sticky rubber side so the papper feeds properly.
Now if you are a heavy printer, you can order some of these from dell for the next time. Washing these in handsaop and water works sometimes too. never use alcohol.
Jan 06, 2008 | Dell 1700n Laser Printer
Paper jams
It sounds like you'll need new feed rollers.  I could find some part #s for you if you felt confident replacing them yourself.
Oct 10, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
165 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
