Question about Carrier 38BRC036 Air Conditioner
Ton Rating for this AC
Can you tell me what it is rated at? Thanks.
  • 958 Answers
It is a three tonner. the number 036 indicates a 36,000 btu that corresponds to 3 tons.
tnx 4 using fixya,
drcool
Posted on Oct 25, 2008
Two ton spilt ac how many mfd capacitor need to be fix
usually takes 25mfd or 30mfd for compressor and 3 mfd for fan motor. Depending on what compressor is used I would recommend 30uf rating for the compressor and it should be fine, most compressor will operate within 10 to 15 percent of rating plus or minus with no problems. Also the 3mfd rating is based on OEM motor, if it has been replaced then probably a 5mfd is required.
Aug 24, 2011 | Ruud Matching Split Air Conditioner
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
I have a GE model No. BTN 748A100A1 (central air outside unit). Serial number 40564128. When was it made? What is its efficiency? It now handles #1950 sq. ft. Cab it handle 2950 sq ft when I remodel?
GE stopped making AC units probably 20 years ago. The same unit will not handle an additional 1000 sq. ft. I believe it is a four ton unit and about a 6 SEER rating which is way down on the efficency scale. You will need a 5 ton system to handle 2950 sq. ft. The average SEER rating now is 13.5.
Oct 07, 2009 | GE Heating & Cooling
Voltage Stabilizer for LG 1.5 ton window type ac
You should have around 120-125 volts at the outlet. If you have less than 110 volts at that one outlet, you may need to have your house wiring checked. Go ahead and call your local power company and have the power coming into your house checked at their transformer. They should do this at no charge to you.
Aug 02, 2009 | Heating & Cooling
Can't identify ton rating of condenser unit
the model number tells me it's a 4 ton. the 048 is what it gives it away. 1 ton is 12,000 btu's . 4 ton is equal to 48,000 btu's
May 23, 2009 | Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Carrier 38BRC036 Air Conditioner Logo
117 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
