Question about Canon imageRUNNER C3200 Color Printer
ERROR CODE E00002-0102
WHEN I PUT ON THE MACHINE IT SHOWS THE ERROR CODE SHOWN
BELLOW ;
E00002-0102
  • 1,219 Answers
Try in service mode * 2 8 * under FUNCTION, clear error- turn off and on.
Its fixing related error
Posted on Jan 13, 2010
  • 149 Answers
You have a fuser problem. You didn't specify a machine but if it is the irc/clc3200/3220/2620 you will need to replace the fuser unit. If you have a different model where the fuser thermistors/thermal fuses etc can be replaced then replace according to the manual.
Canon Copier Sevice Manuals
Posted on Jul 06, 2009
What do I need to get error code as machine is not working
If your machine has a digital display and there is a associated fault with the machine then an error code will automatically be shown in the program window but if there is no known fault then no code will be shown. Some machines use a varying array of flashing lights or beeps to display a fault and with these machines you would need to count the bleeps or note which lights flashed and in what sequence. These fault codes only show when there is a fault with the machine
Mar 28, 2017 | Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/13 error code on...
The error F/13 is shown on the display due to Dispenser Circuit Error detected in the washing machine.
In this problem check the dispenser motor .Either is blocked or its not running in proper direction.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/06 error code on...
The error F/06 is shown on the display due toDrive Motor Tachometer Error in the washing machine. The motorspeed is not getting detected by the control board in themachine.
Frigidaire washing machine model ATF6700FS2. Had it in to a repair place to replace the bellows. The bellows in not centered. I don't know if that would impact this problem. I try to start the machine...
Hello Kerri, thank you for your inquiry!
First, if the bellows is not centered it is highly recommended to get that repair. If you are getting an error code E23, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards!
Sep 23, 2013 | Frigidaire GLTF2940ES Front Load Washer
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/05 error code on...
The error F/05 is shown on the display due to Water Temperature Sensor Error in the washing machine.
Tip
WHIRLPOOL Duet & Duet HT washing machine shows F/H error code on display?
This error is shown on the display due to:--
Water not getting detected while entering the washing machine or
The other possibility is that the Pressure switch is got tripped but its not getting detected.
This happens because in 30 seconds if the control does not detect water entering to the washing machine then the valves will be turned off and the error code will be shown on the display panel.
To solve this problem you will have to check the drain pump.is it properly fitted or got loose or worn out or leaking. Also check the pressure switch hose is in good condition and properly connected to Tub and Pressure switch.
This will help.Good Luck.
2 minute into the wash the F24 error starts blinking on screen.
Hi
Please check this bellow link to remove the F-24 error code:-
http://maytag.custhelp.com/app/answers/detail/a_id/2885/~/display-shows-an-error-code---front-load-washer
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Maytag MHWZ400T Front Load Washer
We have a kenmore elite he5t front load washer, that i just finished replacing the bellow on. after reassembling the front panels, i tried to start the washer to run a cleaning cycle, but all that happens...
Thats usually a sign that the door is still open. Make sure that when you put the bellows on the ring that goes around it was put on properly as well that way the door is actually fully closing engaging the door swithch and letting the machine know its ok to run.
Nov 07, 2010 | Kenmore Elite HE5t Washer
Error Code F33 after new bellow put in. How can I fix it?
Just fixed my F33 error code for GHW9400. This code is for the pressure switch HOSE. Mine had a small pin hole. Cost:: the dealer gave me a free new hose. Remove the top and back. In the top right hand corner (at the back of machine) you will see a small hose attached to the pressure switch box. It is small black& 3/8" and about 2 1/2 ft long coming out of the bottom.. Mine was not attached with anything. Pull off at the top and bottom. Look for even the tiniest hole. Hose probably can't cost a couple of dollers.
Replace and just finished my first error free load. It may be causing your leak too.
Jan 10, 2009 | Whirlpool GHW9400 Front Load Washer
Canon imageRUNNER C3200 Color Printer Logo
521 people viewed this question
old marine
old marine
