Question about Blaupunkt Monte Carlo MP34 CD Player
Blaupunk monte carlo mp34
what could be the problem of this radio even if the accessories wire(red) is not connected the power of the radio can be turn ON?
regards, wilson
  • jason May 11, 2010
    do you mean the radio red wire not connected to power of the car?
  • 899 Answers
If the positive wire is not hooked up then it will not work
Posted on Nov 01, 2008
1994 honda accord radio wont save settings.
If you have a multimeter or test light, try to find a wire that still has 12v when the key is off. Connect that wire to the yellow wire of the radio. The yellow wire has to have constant voltage going to it to maintain the memory.
Feb 11, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
Cant get the power to work on a xd1222
If the radio is correctly installed and, there is no power on the vehicle's accessory wire when the key is turned on, check the vehicle's radio fuse. If you connect the red to constant 12 volt along with the yellow radio memory wire the stereo WILL NOT TURN OFF. There is nothing strange about that.
Oct 14, 2012 | Dual Electronics XD1222 Car USB Player
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Chevy Radio Help (DUAL Radio)
You need to connect the red wire to a switched power source. The radio will not work of there is no power going to both the red and yellow wires. Yellow should be going to a constant power source (a source that is still hot when the key is off) as it controls the memory for the clock and preset stations. The red wire should go to a source that turns of when the key is off (accessory or ignition).
Apr 23, 2012 | Car Audio & Video
I have a 1985 chevy monte carlo and I have ran a wire from my fuse box for a constant n my cd player will not keep memory and my memory is fine on the cd player.iv had several cd players in this car and...
You must have tied into an Accessory fuse and not a constant. Typically Cd player/radios etc will need both an Accessory tap as well as a constant tap.
Test the voltage on the wire and if it's constant you will have 12VDC without the key in the ignition You will also need a tap where there is 12VDC ONLY when the key is in ACC mode (or ignition on)
I do not have specific details on your CD Player but consult the manual on adding both of these connections,
I hope this helps
Magoo
Mar 11, 2011 | Kenwood KDC-X794 Car CD / USB/ MP3 Player
Where do you connect the memory wire on a jvc kd g110 car stero.....what color is the memory wire ?? what does hook red wire to acc fuse mean??? what wire does the red wire on the radio connect to on...
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Mar 02, 2011 | JVC KD-G110 CD Player
The radio will not hold memory
If your radio will not hold memory then you are lacking a constant 12 volt power source. Check the yellow and red wires at the radio. The yellow wire should be connected to a constant 12 volt power source (battery) and the red wire should be connected to a switch 12 volt power source (accessory or ignition).
Nov 23, 2010 | Pioneer DEH-2800MP CD Player
No coad
Try asking here
www.ukbookshelf.co.uk
Jun 19, 2010 | Blaupunkt Monte Carlo MP34 CD Player
Installing a kenwood kdc-135 in a 2001 monte carlo ls
Hello, my name is Israel and I will help you. The following should be able to help you out. Please rate and good luck.
constant 12+ orange
switched 12+ yellow
ground black/white
illumination gray/black
dimmer brown white
Left Front + tan
Left Front -
Apr 13, 2010 | Kenwood KDC-135 CD Player
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Blaupunkt Monte Carlo MP34 CD Player Logo
189 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
