Question about Intel D865GBF Motherboard
Bios hagging help
My board is d865 board pin processer and on board vga.my bios hangs when trying to go to bios setup and display a message operating in single phase what could be the problem
  • Anonymous Oct 31, 2008
    but i cannot go to the bios setup,in that even i cannot view the devices that are attached to my machine,eg hard drives floppy,and cd rom.when i try to press del key to enter the setup it hangs telling me entering setup
    Problem Solver:
  • 4 Answers
I think problem with your BIOS
http://downloadcenter.intel.com/download.aspx?url=/12687/eng/SC1-032P.BIO&DwnldId=12687&ProductID=2441&lang=eng
Download this .BIO file from intel Web site & Copy it to floppy disket & remove your CMOS Jumper, insert your floppy & turn on your pc after few beeps pc will automaticall turn off. replace your CMOS jumper & turn on & load BIOS default valus.
* use Good working condition floppy drive & full formatted high density floppy disket (new one) & UPS for backup.
Posted on Oct 28, 2008
Press DEL to enter Setup, Press TAB to display BIOS POST message"
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2V&p=1&s=24
Try to download the manual, by selecting your windows system.
Open the manual folder, and click on global for download.
You might need to upgrade the bios, to support windows 7, and certain harddrives.
You also need at least 2 gb ram, for the install.
Good luck
Jan 25, 2013 | ASUS M2V Motherboard
How i solve supermicro x8dt3-f display problem
Make sure JPG1 is jumpered between pins one and two.
Pin 1 is on the left.
JPG1 is on the very bottom of the motherboard, near the end of the PCI slot.
Next go to Advanced Setup Configuration if you can get any video, and check Boot Graphics Adapter Priority.
Make sure it is set to Onboard VGA.
If no video, reset the BIOS.
Onboard VGA is the default.
Jun 01, 2011 | SUPERMICRO COMPUTER Supermicro X8DT3...
Hello, I have a Intel esys 865 gv / 775 motherboard. and win xp installed. The system hangs up after about 5 minutes after booting up. No error messages are displayed. all cooling fans are working. and...
Your system is probably hanging because of high temperature. Check cpu temperature in bios hardware monitor. If it is to high check the heatsink is fitted properly also apply thermal paste between processor and heatsink.
Mar 08, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I got a PCIe Graphic card but apparently even after i have fitted it perfectly into the slot, the display won't switch to the graphic card from the onboard video.please help.
You will go to BIOS SETUP and press F2/F10/ Dell
Disable on Bord VGA or set the graphics piority
http://www.pcbuyerbeware.co.uk/BIOS.htm
FOR VGA
http://www.pcbuyerbeware.co.uk/AGP.htm
1st pci slot
2nd on-board VGA.
Follow link
It will help you.
Regards
Shibuda
Jan 05, 2011 | MSI 945GCM5 Motherboard
My mother board D865 GBS cannot accept drivers from CD only VGA drivers. Audio or LAN card drivers are ok.
Dear Asif,
Click here to download the drivers for Intel D865GBF Motherboard. (It has Intel Extreme Graphics D865)
Choose your Operating System and get the drivers
Hope this helps! Dont forget to rate the solution!!
CreativeTECH
Nov 29, 2010 | Intel D865GBF Motherboard
No display assus motherboard PSN73-AM ASUS MOTHERBOARD
When the PC starts up, do you get a BIOS display at all? Try fitting a graphics card into the board instead of using the built in port, if that works check the BIOS settings to see if the built in adapter has been disabled,
Mar 26, 2010 | ASUS P5N73-AM Motherboard
Hello, i have disabled the option NO INTERNAL DISPLAY on bios afterhavingthe restart i have no display
It is because you turn off the onboard vga device in your motherboard that is why you don't have anymore display in your monitor. This will happen often if you don't have a separate video card in your system and you only use the onboard. To solve this problem, you should reset the bios of your motherboard. To do this refer to the motherboard manual.
Oct 31, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Wont boot
No VGA Drivers our mother board
Oct 30, 2008 | Gigabyte GA-945GCM-s2C socket LGA775...
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
Intel Desktop Board D815EEA2
Leave the connection to graphics card in, and take the left side panel off the pc and on the motherboard, you will see either a terminal marked CLRCMOS,JBAT1, CLRRTC, RTC, this is the cmos clearing jumper to revert back to default and the need to reset the time and date. If it's JBAT1 3 pin terminal, the cap will need to be taken off pins 1-2 and put across pins 2-3 then back to pins 1-2. If it is one of the others and only a 2 pin terminal, use a jumper cap like the one on the back of your hard disk and cdrom drive and put it over the 2 pins. start up pc and you should get the screen a beep and it will say press f2 for cmos setup, correct the date and time and the bios should be reset to vga, so change to pci again.
Apr 18, 2007 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Intel D865GBF Motherboard Logo
66 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
