Question about Gestetner DSM 651 Copier
Sc541 ricoh copier 1035 with code sc541
  • Anonymous Mar 12, 2014
    functional problem whithin the copier sc541
TRY REPLACING THE THERMISTER WHICH IS NEAR MIDLE.
Mohan
Posted on Oct 25, 2008
Como entrar en los codigos de servicio pra resetear el sc541 en gestetner p 7575
sc541 means you need service techinican to come and fix your machines
Jun 20, 2011 | Ricoh Aficio 1035 Copier
I have nashuatec1805aficio, it have sc541 error display on the screen.I have tried clear by using yellow key then 107 then red key hold down for 3sec.after that i press 1 on SPmode display then it display...
sc541/541 is a fixing problem, check if your thermistor or thermal fuse are defective, if yes replace them or clean the thermostat/thermistor. then reset it by pressing the yellow key then 107 then red key hold down for 3sec.after that press copy sp then exit turn off machine after 10 sec on. hope this helps
May 28, 2011 | Ricoh Aficio 1035 Copier
Ricoh aficio 1045 - SC541
Fusing thermostat/thermistor open
Symptom: The fusing temperature detected by the
thermistor is below 10°C for 5 seconds
after the main power switch is turned
on.
Possible Cause:
• Fusing thermostat defective or out of
position
• Fusing thermistor defective or out of
position
• Power supply board defective
May 25, 2011 | Ricoh Aficio 1035 Copier
GIVING ERROR CODE SC541
SC541 or SC542 is a fusing problem clean /check/ replace thermistor 1 and 2 and fuser fuse 1 and 2, these are located on your fusing unit
May 21, 2011 | Ricoh Aficio 1035 Copier
Sc541 ricoh 1060
Verify the fusing unit contacts,thermistors and thermalfuses,heater lamps continuity.If is OK enter in the service mode:press yellow key -1-0-7 and press and hold 4 seconds the C red key.When appaire to the touch pannel service menu or copy sp press the windows,open the front door,close the copier machine on the main button and wait 10 seconds.Press ON the main switch close the front door and make a copy.If anywhere is replaced the heaters lamp,check the contact in the back side Orange wire to Orange wire,and the Red wire to Red wire contacts.
Dec 02, 2010 | Ricoh Aficio 1035 Copier
Code error SC 541 ricoh aficio mp2550
SC541 is a Fusing thermistor open (center) The temperature of the hot roller remained below 0oC for 5 sec at the center of the hot roller. Fusing thermistor out of its position because of incorrect installation. Fusing thermistor disconnected or defective power supply not within rated range (15% or more below rating). Try cleaning or replacing the thermistors and reset code in service mode.
Jan 30, 2010 | Ricoh Aficio 1035 Copier
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
I have a sc541 problem
hello sir; you need to reset, following the steps as below;
press "clear mode" then enter107 then press and hold down "clear/stop" key about 3 sec. or more, then turn power off and back on .
Feb 04, 2009 | Ricoh Aficio 1035 Copier
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Gestetner DSM 651 Copier Logo
459 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
