Question about JVC AV-35750 35" TV
TV has bright horizontal line
My tv turned off an on continously. I replaced a condensor C901 and now it stays on with a black screen and a bright white horizontal line. I replaced condensor C421 and have resoldered the vertical IC. I have sound and can run channels. Can some one help?
  • Anonymous Nov 05, 2007
    sound stays on bright narrow horizontal line at the center of the screen, wish to know if repairable or not
  • 68 Answers
Do some voltage checking on the ic and make sure that volages are reaching there, about 32 volts. if it is reaching, then you can change the ic there. but before you do that, check around that ic and make sure everything is ok there. good luck
Posted on Apr 08, 2007
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
At first it was lots of horizontal lines over the screen, and later TV screen went completely black. The sound still is perfect. Perhaps I just need to replace the fuse? I love this TV! Thanks...
Hello
You have stated that your TV has a lot of horizontal lines before it went off picture. We say that lines as retrace lines. So many of them will there on the entire screen, at about one inch or so apart, horizontaly scattered along with picuture. At that time, you may be unable to down the brightness control also. Even though you have reduced the brightness control to zero position, there will be some brightness level on the screen. You should have to repair that fault at the begining. There is a voltage going to the picture tube base, known as screen voltage. That voltage determine the emission of the picture tube, and we call it a bias voltage. When it goes higher than normal, this trouble ie retrace lines will occur. In long run it may spoil the picture tube itself. I don't know what the case of yours.
Anyway it is best for you to consult an experience technician in this case. Ok.
Nov 05, 2010 | Sony KV-35V35 TV
Black screen with bright horizontal line through center
Your vertical IC may need resolder. You may have a bad capacitor or two that created an extra warm IC and create bad grounds. So resolder and check those caps near and around your vertical IC. If you continue to see this horizontal line you may have to replace the vertical IC. And you may as well check all grounds as well. Good Luck and be careful!
Jun 18, 2010 | Broksonic TV
The brightness is very dark. Any nightime scene
Your CRT's getting old. Plus dust on lenses don't help much. You have to open front frill (below screen) and back of the TV. Clean up lenses using dry paper towels, do not wet.
In front of the TV after grill remove center cover and locate "black box" that have 6 potentiometers on it that looks like plastic adjustment screws for philips #2 screwdriver slots. 3 of them should read "Focus" These you don't touch. Another 3 reads "Screen". Put some still image on your screen (like paused DVD movie frame). Carefully add brightness in all 3 colors trying to avoid horizontal lines appearance. If lines show up, just turn it back a little. Try to keep color balance looking at the picture.
This procedure will brighten up image but further reduce CRT's life.
In case that you posted wrong model here and you have DLP Projection TV - just replace the lamp.
Mar 09, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Won't stay on
The quick horizontal line through the center of the screen usually denotes a failure in the vertical output circuit, and that would keep the set from staying on. You would have to take it to a repair shop for repair.
Dec 09, 2006 | Mitsubishi CS-31305 TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
96 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
