Question about HP xw6400 Workstation PC Desktop
Boot HP xw6400 Workstation PC Desktop blue screen on start up
Chuck68
  • 42 Answers
SOURCE: It will boot up to the windows screen and freezes.
If your computer was able to boot up but unable to load the Windows, the most common cause would be the recently intstalled software or Windows update.
To remove this, follow these steps. Skip Step 1 if it is not relevant.
Step 1: Removing recently added hardware
Use the steps in this section to disconnect any recently added hardware and test for the error.
NOTE: If a new internal device (sound card, hard drive, or other) was added to the computer before the error message started to occur, you have to remove it before continuing.
  1. Turn off the PC and unplug the power cord.
  2. Disconnect the mouse, and any other peripherals attached (Printer, scanner, webcam, zip drive, phone cord, network cable and other devices). Leave only the keyboard and monitor cable attached.
  3. Press and hold the power button on the front of the PC. Release after 10 seconds.
  4. Plug the power cord back in.
  5. Turn on the computer.
  6. The computer displays the We apologize for the inconvenience... message. Allow the timer to count down from 30 to 0.
  7. If the computer successfully starts to the Windows desktop and does not restart to the error message, connect one device and wait until Windows recognizes it.
  8. To find if a device is causing the error, continue connecting the devices, one at a time, restarting the computer each time, until the device that is causing the error is found.
NOTE: If this does not solve the issue try to do a system restore BUT it will delete all your files and programs you install by yourself after the system. You will be able to use the pc as a new pc.
Posted on Jan 25, 2009
Kiranbala
  • 91 Answers
SOURCE: HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Posted on Mar 07, 2009
SOURCE: HP Workstation XW6200 starts to power up and then
First open cpu cabinet.
Then Refix your RAM memory .
Reattach ATX power connector from SMPS to motherbord.
Remove pci cards from PCI slot.
Pull cmos cell from motherbord for 10 minutes so all motherbord settings are defaults.
Reattach both connection to harddisk.
Make sure your harddisk is detected in bios.
When you power up the computer press F1 or F2 or "del" key to enter in bios.
Then check harddisk is detected.
Let me know if you need more assistance.
Thanks.
Posted on Oct 04, 2009
Turk_97
  • 131 Answers
SOURCE: BLUE SCREEN ON HP WORKSTATION WHEN I TRY TO
Are you trying to do a fresh install? or upgrade from another operating system? Generally have to do a fresh install when going from 32 bit version of xp to 64 bit. IF you have more than 4 GB of ram installed, you may have to remove some, then install 64 bit XP Pro, then install your ram after. (this is a known problem with some machines and 64 bit xp) IF this is none of the above?
Please add a comment with more information as per your BSOD. This way I can identify with you what it is the system does not like
Posted on Oct 08, 2009
SOURCE: HP Pavilion Elite m9517c Desktop PC stuck on welcome screen
hi
there is problem with windows OS
u have to reinstall wondows befor you go for reinstall just tak backup from you C drive
Posted on May 21, 2010
Windows 7 not installing in Hp XW4100 workstation
Sounds like you need to format the hard drive then try a new install
Jun 21, 2012 | HP Workstation Xw4100 PC Desktop
P7-1020 will not boot or power up
sounds like o/s and hard drive are really not too happy
start with F8 pressed down while powering up to see if you can get to safe mode
Jun 16, 2012 | HP Pavilion BV704AA p7-1020 Desktop PC -...
New ram not working
Sounds like you bought the wrong kind of memory. It should be DDR PC2100 and it must be ECC (Not None Ecc).
Take a look at this site.
http://www.4allmemory.com/memory/compaq-hp-workstation-xw6000/
May 11, 2012 | Compaq HP Workstation xw6000 PC Desktop
Monitors will not turn on due to a power spike. Tower makes a beeping noise with a red blinking light. What could be the problem?
The moitors did not turn on at all after the power spike?
If that is the case, probably some electronic components were burned due to power surge damage.
I advise you to contact the manufacturer for repair and your local electricity supplier.
The beeping noise and the red blinking could be indication that no monitor is plugged in.
Jul 06, 2011 | HP xw6400 Workstation - 2 x Intel Xeon...
BLUE SCREEN ON HP WORKSTATION WHEN I TRY TO UPGRADE TO 64 BIT XP PRO
Oct 08, 2009 | HP xw6400 Workstation PC Desktop
HP Workstation xw6400 hang every 10 to 15 min.
Check for any virus. Check disk manager for any hard disk manager. if disk is ok  replace your memory with a new one
Apr 09, 2009 | Microsoft Windows XP Professional for PC
HP xw6400 Workstation  PC Desktop Logo
103 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
