Question about Kyosho Toys
Esc perfex ka-15 - Kyosho Toys
  • 88 Answers
SOURCE: Blown Electronic Speed Control on Team Losi Mini-T R/C Trucks
I believe that the ESC and receiver are one combined unit on these trucks. I know it is on the Mini T but I am not sure on the Mini LST2. I would contact a local hobby shop or go to Tower Hobbies web site to find out how much a replacement unit is. It might not be worth the trouble since you can buy a new Mini T for about $100.
Posted on Dec 10, 2009
SOURCE: Novatech High Speed HSP Brushless 70A ESC for Cars, Buggi: i need to no how to program my novatech 70 amp esc...
throw it in the garbage
Posted on Nov 07, 2010
rockmeister
  • 2047 Answers
SOURCE: Greetings, I have a radio controlled
Usually radio controlled units seem to be coming up with a lot of problems recently as a result of the intense weather situation. Although other explanations abound for the various radio problems.
With your unit several issues could be wrong. The first being the escape button malfunctioning this could be due to a partial contact inside the system thereby the escape button being pressed down as the symptoms you have explained are the signs evident when you press down the escape button.
The second could be as a result of a battery malfunction try replacing the batteries in the unit and check what the reaction will be.
Hope this solution has been helpful?
Posted on Jan 08, 2011
  • 19 Answers
SOURCE: xl5 esc stopped working. light will not come on. i
i had the same problem and what it turned out was when i tried a new battery it worked seems that the battery may have been fried
Posted on Sep 19, 2011
coskuarsiray
  • 210 Answers
SOURCE: problem to connect walkera cb100 esc controller connector
there are only 3 combinations on connecting esc to brushless motor. if nothing indicated on wires you can try each combinations of 3 wire by keeping 1 wire choosen and trying rest 2 wires. dont worry you wont burn anything. only motor runs on other way.or it wont move but makes noise.
Posted on Nov 18, 2011
My HP Envy 15 doesn't turn on but there is white LED lighting without the battery, or amber LED with the Battery. I am at a standstill on figuring this darn laptop out. Any suggestions?
please check dc jack first if there is power problem with a laptop, I see HP Envy 15 uses a few different dc in cables, please indicate the exact model number, or this site may help you: https://www.dcincable.com
Jul 15, 2017 | HP Computers & Internet
Esc light stays on / what is esc
ESC= Electronic Stability Control and is part of the ABS braking system, the button to turn this off is the same button to turn it on! Press once for off and again for on!
Oct 29, 2014 | Cars & Trucks
ESC OFF is switch on
Yes, and press the switch and ESC will turn on. The switch enables or disables the ESC. When you turn off the vehicle and turn it back on, the ESC will automatically turn on regardless of whether it was on or off when you last turned the car off. If you want to keep the ESC disabled, you will need to push the button each time you start the car. The ESC is not the ESCape hatch. It is the Electronic Stabilization Control. This is a computer operated system of interworking devices that help keep the car stabilized and driving correctly. It includes the antilock braking system, the antiskid system and the traction control system (if equiped).
Mar 08, 2014 | 2006 Hyundai Sonata
I want to reset my Epson LQ 300 +2 printer to its factory defaults. can you help?
Turn Off Printer Hold LL/FF , Load/Eject and Pause Buttons then turn on printer
May 08, 2011 | Epson LQ 300+ Matrix Printer
I need to rebuild the inside of a traxxas xl-1 esc i need the bord layout and wireing
You can send it back to Traxxas and they will repair it for $15 plus $5 shipping/handling if there is no signs of abuse. A new xl-1 esc is $60 from Traxxas.
May 19, 2010 | Traxxas Rustler Stadium Truck
Bypass code for dual xdvdn9131? is there a bypass code for this new unit?
dont need a code just get a toggle switch and hook that to the yellow/blue wire and with the other side ground to the small lil screw where you will see a small lil short wire and then all u have to do is fallow the screen with the e brake but just flip the switch 3 times with the whole one sec then off for 3 sec then on
Feb 18, 2010 | Jensen VM9510 Car DVD Player
ESC light on/Now it says ESC OFF
Electronic Stability Control (or ESC) is a new crash avoidance system found on many vehicles. Unlike air bags, which only help you during a collision, ESC will help you to avoid loss of control that could lead to a collision.
ESC is designed to help you stay in control of your vehicle during an emergency manoeuvre, such as when you need to swerve or brake suddenly to avoid an obstacle.
ESC monitors your steering versus the direction of the vehicle. When they do not match, ESC will automatically actuate the brakes at one or more wheels for short periods of time, reduce engine power, or both. If at all possible, ESC will help you maintain control of your vehicle.
ESC is automatically "ON" whenever you start your vehicle. Some vehicles have an ESC Off switch; this switch is needed to disable ESC during certain situations such as when you are stuck in snow. If your vehicle has an ESC Off switch, refer to the vehicle owner's manual for more information. Unless you manually shut ESC Off, it will remain active until you turn the engine off.
Please rate this fixya
Jan 27, 2009 | 2007 Hyundai Sonata Limited Sedan
Esc light comes on and car wont go into park or any other gear other then D and N.
Jan 17, 2009 | 2007 Hyundai Sonata Limited Sedan
Toshiba Satellite 1415-s173
Hold down the Esc key when you turn on the system. Assuming your Esc key works, that'll trigger a "Hit F1 to continue.." message and take you into the BIOS.
Jul 04, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Toys Logo
121 people viewed this question
Top Kyosho Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kyosho Toy Expert? Answer questions, earn points and help others
