Question about Maxtor MaXLine Plus II 250GB 7200 RPM Portable External USB (250GBEXT) Hard Drive
Unable to see the 250Gb external drive shown on 'my computer' when plugged in
See one line question above
  • noooooooo Mar 30, 2009
    What if disk manager won't see it but device manager does - No it doesn't get assigned a disk letter
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    unfortunately, the way this diplays, that is not feasible..please repost it so we can read it..
  • 4 Answers
Hi i had the same problem. I found that this did the trick for me:
Try looking for the drive in the "Disk Management".
Right click on "My Computer" or "Computer" and select "Manage" then select the "Disk Management" item.
If you can see the drive, but there is no drive letter assigned, you may need to format it for your operating system or create an accessible partition on the drive. You can access all these options by right clicking on the drive from the "disk management" screen that you should be on.
mine needed to be initialized (by right clicking on it) and then i formated it
Good Luck!
Posted on Oct 26, 2008
Hi - thanks for your quick response, much appreciated .........I will try again to explain!!
We have purchased a 250Gb Maxtor portable hard drive which I was told was plug and play. We have followed the instructions for connection but no drive letter is showing up and the external drive is lit up and making a constant beeping noise. The computer doesn't seem to be recognising that an external drive has been connected.
To test our computer out I have connected an 8Gb memory stick to the processor and it shows up as drive H immediately.
FYI - we have XP running on our machine.
Hope you can help!! Thanks
Posted on Oct 25, 2008
Unable to read external HDD after plugging it to a Mac (previously it is readable via a Windows PC)
Chances are it was formatted as NTFS format by the PC which is not MAC compatible. You will need to reformat the drive in HFS format if you want it to work as a MAC disk only or in FAT32 format if you want to read it in PC and MAC machines.
Jul 24, 2014 | Western Digital WDG1C2500N MyBook Premium...
Plugged in external hard drive and does not appear on desktop
Go to Administrative Tools>Computer Management>Disk Managemant and see if the drive appears there. If it does, you may need to delete the partitions on the drive and create new ones. If this doesn't work, you may need to contact the manufacturer for a possible replacement.
Mar 14, 2014 | SimpleTech 250GB USB2.0 7200 RPM External...
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
I have Fantom Drives Titanium 250GB i am not able
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 30, 2010 | Fantom Titanium 250GB External...
When I connect my buffalo driver the yellow light flashes and I am unable to locate the external drive on my computer.. HELP!!!!
Try to plug your External Drive to other usb port or to other computer, or change the cable.
let me know the result.
dm
Mar 21, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
I cannot retrieve my files from the wd 250gb
First instinct is that your drive has failed. I would remove the drive and insert it into a system to test. If it works, then it is the housing from the external drive that failed. If the drive does not work once inside your system, then the drive is bad. Good luck.
Jun 04, 2009 | Western Digital 250GB MyBook External USB...
Undetectable External hard drive
i am unsure about this but its worth trying
go to start control panel administrative tools services and look for plug and play and make sure it is set to auto at start up and enabled it so it is started this lets your computer recognize new hardware on your computer which should let see it in your my computer screen
i hope this as help if not well i tryed
Apr 17, 2009 | Verbatim SmartDisk Firelite Portable USB...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Maxtor MaXLine Plus II 250GB 7200 RPM Portable External USB (250GBEXT) Hard Drive Logo
240 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
