Question about Kenmore 24032\24036 Top Load Washer
Washing machine will not start unless lid is slammed shut
appldoctom
  • 311 Answers
SOURCE: Washer doesn't spin or drain unless I open the lid.
hay this is a tougher one .i tried to find a wiring diagram but couldn't.so ill tellyou what im thinking.when it stops and you lift the lid and it gets going is the clue,we know motor ok it will spin .we know lid switch ok you replaced.sooooooooo take a look at your diagram and see what componets come into play by way of the lid swtch opening then closeing.some how power is diverting may be to timer..........wow you gave a pretty good report on whats going on.so im reading and the running it in my mind.you say it will agaitate until in off position.so im thinking how can that happen.there has tobe a contact point stuck.when unit gets to end of washs cycle it should pause and wait to empty then refill or spin if after rinse .the presure switch tells the timer that has been done,but if presure switch bad washer may over flow or not fill so it seams fine.thinking.......you could use the process of elimanation but that could be expensive.thinking.........could the presure switch hose be blocked ,fooling the system? clean blow out.there can be no water in it before the tub fills..........you can blow thru tube while attached to presure switch and with ohm meter make sure its switches are working........but check all you can to elimanate the eazy stuff and go from their.i hope ive been some help.you can email if any questions .God bless ,tom
Posted on Jan 08, 2009
  • 4088 Answers
SOURCE: Whirlpool Ultimate Care top load
Likely, the lid switch needs position adjustment or replacement. Open the top cover to access the switch. Connect the two switch wires together and tie up so that they can't short out to anything, then run the machine a couple of times to see if this fixes the primary problem. If so, reconnect the wires, then try the switch adjustment for fix, then replace the switch if adjustment fails.
Posted on Sep 07, 2009
  • 1937 Answers
SOURCE: I have a Kenmore Elite model # 110 26962500 that
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26962500+
Getting to the Lid Switch on these machines is about a 5 minute job.
First, unplug the machine.
Looking at the Sears diagram for the console, you'll see that underneath the corners of the console are two clips. Using a thin putty knife, push on these clips from the front and the entire console should tilt backward.
Looking at the diagram for the cabinet, you'll see the lid switch.
Although most top load / direct drive Whirlpool / Kenmore washers only use the lid switch during the spin mode, yours may be a bit different.
See the following Whirlpool service manual for the top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Usually, the problem with these washers not agitating points to the Motor Coupler.
Since you already have the console tilted back, it's another 5 minutes to pull the cabinet off and check the coupler.
See the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler is worn or damaged, replacing it takes about 10 minutes .
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. Hitting the cabinet may allow the coupler to grab and transmit power.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Oct 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a kenmore elite model 11026942500 top load
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
TheMobilian
  • 8220 Answers
SOURCE: Why do I have to slam the lid for the wash to
Your lid switch is on the way out or the hinge is loose or the lid strike is out of alignment. The lidswitch is located here
To replace it and check it you flip up the controls
The switch has 3 wires. A green ground wire and 2 hot wires. Bypass that switch by jumping out them 2 hot wires and the washer will work but you should not leave it that way if you have others around that may get hurt foolin around with the washer while it is in the spin cycle. Folks have had their arms severely damaged by trying to grab clothes while washer was in spin. So all washers are equipped with a safety lid switch. Thank you Ralph Nader. Here is a video which shows how to replace the lid switch:
I have videos, a service manual and more HERE
Posted on Jan 08, 2011
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Want start unless you slam lid or push start knob in and out
HI, Check and see if the door hinge screws are tight. Sometimes the hinge loosens and the lid switch will not activet properly. It the lid is tight, you might have a lid switch going bad. The lid switch is located under the control panel. There is a screw in each corner of the control panel in the back side. Loosen these screws and lift the control panel up and it will rest on the hinges.
Ths lid switch is to the left and should have three wire to it. Parts# 8318084
I hope this helps you. If I can assist you further or you need a place to order the lid swtich, please give my web site a chance at www.whirlpoolpartssurplus.com
Thanks
Vic
May 22, 2009 | Washing Machines
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not go pass the wash cycle to spin or drain
There is at least one safety switch activated by the lid.
Depending on machine construction, these are somewhat exposed to water incursion that eventually causes them to fail.
The slamming of the lid is causing the failing switch to make enough contact to allow it to spin.
If you are lucky (I don't know your machine), these may be located toward the rear of the housing where they can be fairly easily replaced.
Jul 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Have to slam the lid
The same thing happened here. It turned out to be the lid switch. It can be accessed by taking off the back plate (behind the controls) by unscrewing three screws and two screw bolts -simple.
I removed the lid switch and tested it with an ohm meter - instructions are on this site. You should have continuity across machine-motor, as well as across machine -line. (These are labeled on the switch).
If you don't have a meter and you still want to see if that's the problem, after you have removed the lid switch, short the machine and line connectors, (you'll see these labeled on the lid switch so you'll be able to figure out which wires go with what) as well as shorting the machine and motor connectors. Both of these need to be shorted. That bypasses the switch and will activate the motor and controls.
That's what I did to confirm that it was all a "lid switch " problem. I ordered a lid switch from this site for $24.95 for the repair, and will use the "shorting process" to do a couple of loads of wash as I wait three days to get the switch. Good luck.
Dec 16, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washer won't start after lid is shut, if i slam it, it works!
sounds like your lid switch is loose ..look at the tab that sticks out of the lid and watch where it close's. inspect the switch see if it is loose or broke
Nov 28, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
409 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
