Question about LG Heating & Cooling
How to rectify ch 06 error on my lg bmnc09g2bl0 air con
  • 234 Answers
SOURCE: LG error CH 64
What is the model of the unit?
Posted on Apr 07, 2009
hvac1960
  • 2133 Answers
SOURCE: LG air conditioner 24awn error code message Ch 6
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Posted on Dec 13, 2010
hvac1960
  • 2133 Answers
SOURCE: LG B30AWY fault code ch
Outdoor unit PCB EEPROM failure, try removing EEPROM and refitting if removable (possible contact fault), otherwise replace PCB if the EEPROM is non removable.
thanks.
Posted on Feb 07, 2011
SOURCE: Air conditioner is turning on
Hello Naeva
Plesae visit the link provided below :
http://www.mylg.co.uk/data%20for%20site/Multi%20F_dx_%20Fault%20Codes%20-%20Nov%2007.pdf
http://www.abacusairconditioning.co.uk/lg%20split%20codes.pdf
http://www.ehow.com/info_7983149_lg-air-conditioner-error-codes.html
Posted on May 01, 2011
SOURCE: LG BMNC09G2BL0 error code chn 5
the pc board of the outdoor unit must be replace.
Posted on Nov 30, 2011
Nov 28, 2011 | LG Heating & Cooling
I have an error code ch 61 on my LG system
Hi, Please open the front panel of the air con and look for the reset button on the electronic board, press it once. the system will initialize, then you will see all the LED lit randomly wait for a second then closed the front panel and test it. thanks
Apr 24, 2011 | LG LS-L1210CL Mini Split Air Conditioner
LG B30AWY fault code ch 12. air con unit not working. any ideas???
thanks.
Feb 07, 2011 | LG Heating & Cooling
I have an LG ducted air conditioner and have an CH32 error. Can anyone tell me what this is? Thanks
CH-32 compressor discharge temperature too high. If over 105°C, check refrigerant charge.
Check and rectify the followings:
If over charged-release some gas./If less rpm of fan motor-replace capacitor./Condenser block-Clean it.
Jan 02, 2011 | LG Heating & Cooling
We have LG air con system (hot and cold) coming up with error code CH33. What does this mean?
CH 33 -Excessive rise of standard compressor discharge temperature. If over 105°C check refrigerant charge. Over charged, release little gas still to normal PSI. If condenser full of debris, clean it.
Dec 18, 2010 | LG LS-L1210CL Mini Split Air Conditioner
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
Model ABUW426KSA3 getting an error message "Ch 06"
Is a problem with the Indoor unit coil outlet Thermistor.
Please check this link for the solution. You need to compare a result to a graph in this link. Please go to page 7.
Cheers.
Thank you for using Fixya. Your generous rating will be much appreciated.
Oct 13, 2010 | LG Heating & Cooling
Air con indoor unit is flashing 6 times out door is off
Please specify the make and model of your unit.
If this is a LG inverter model.
The six flashes of the indoor unit light indicates a CH 06 alarm.
This alarm state indicates that the indoor unit pipe temperature sensor has measured a temperature out of range or the unit is protecting itself from this low temp state. Indoor unit coil temperature to low. Should it have reached a temperature of -5°C for longer that 30sec it will switch the machine off.
It could indicate that the unit refrigerant charge is too low or the sensor has gone out of calibration.
It should measure 5kΩ @ 25°C
Mar 16, 2010 | LG Heating & Cooling
Error code ch06
falla en modelo f y multi f xd
error ch 06
sensor de salidad outdoor
solucio0n posible....
estar abierto o en corto
soldadura defectuosa
falla en el circuito interno
Feb 25, 2010 | LG Heating & Cooling
Error ch 5
check all wiring and connections - ch 5 is a communication error between the indoor unit and the outdoor unit......
Dec 09, 2007 | LG LSC183VMA Split System Air Conditioner
Heating & Cooling Logo
32 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
