Question about Bosch Refrigerators
Ktr18p20gb bosch larder fridge require manual
I need to change the bulb
  • 87 Answers
SOURCE: How do I change the
reach behind the flap and pull on it .
Posted on Jul 12, 2008
mastatech
  • 478 Answers
SOURCE: Replacing fridge thermostat
Should be prtty easy the wires can go either way, and just follow the bulb to install in same position
Posted on Mar 14, 2009
SOURCE: Hi Where can i down load an instruction manual for
go to there website you should get all the details you need there
Posted on Apr 22, 2009
woodchuck789
  • 4059 Answers
SOURCE: Bosch larder fridge door pops open
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Oct 19, 2009
Testimonial: "Didn't identify the exact fault, but his valuable insight helped me find a very similar fault in my fridge."
  • 478 Answers
SOURCE: hotpoint larder fridge RL150G keeps freezing at the back fitted n
flap controling tempature not closing to controle tempature 9inside ref
Posted on Dec 10, 2009
How do I remove the light bulb cover on my Frigidaire Larder Elite RLE 1099A fridge
Look for a screw that holds the lens in place. If nada then small tabs on side of lens click into the wall. Squeeze the sides of the lens and that should free up the lens.
Jun 22, 2016 | Frigidaire Refrigerators
I have a KS38R420GB Siemens larder fridge. In the last few months I have to keep changing the bulb every 2-3days. I am using the correct bulbs. what could the problem be.
The first thing I would do is check the light switch by depressing it with my finger. It may be that the lamp is not turning off when you close the door.
Sep 25, 2010 | Refrigerators
The Larder fridge part of my Ariston
sounds like the defrost drain is froze up use hotwater and blowdryer
Jan 29, 2010 | Freezers
Hotpoint larder fridge RL150G keeps freezing at the back fitted n
Dec 09, 2009 | Refrigerators
Bosch larder fridge KSR stopped cooling - has been diagnosed as thermostatic probe broken - now been informed this cannot be replaced? Is this true? The negineer claims that the fridge is no longer...
if he means temp sensor he is correct as they are foamed into the liner in manufacture you would destroy the liner to reach it however there are repair kits available for some models which bypass faulty sensor and allow it to run on ambient sensor you will need to check with bosch tech dept to verify this.
Nov 10, 2009 | Bosch Refrigerators
Oct 19, 2009 | Refrigerators
Mar 14, 2009 | Refrigerators
Larder section of fridge not functioning
check the drain that is inside of the freezer compartment at the bottom. you may have to disssasemble the covers to get to it. if its clogged the water turns to ice real quick and blocks air to the refrigerator
Dec 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
93 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
