Whirlpool Calypso GVW9959K Top Load Washer Logo
Posted on Oct 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Taking the spinner off
I have a pair of hose struck in the spinner, how do you take the spinner off
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 324 Answers
  • Posted on Nov 03, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
324
Questions
Helped
120808
Points
632
If you are calling the washplate the spinner pry off the dome then take out the six or eight bolts holding it down.
2answers
Defy twin tub 800. Why is the washer drain water filling up spinner drum?
The 'flat black round rubber' part is a non return valve so that water can't flow back washer to spinner, or spinner to washer. That part needs replacing. These machines are not available to us in North America, but this link should work well for you.
https://www.google.com/search?q=Defy+twin+tub+800+parts
Recently my dishwasher KUDSO1FLSS2 is not cleaning the top rack very well requiring multiple washings. Both the top spinner and mid rack spinner (under top rack) turn freely by hand but limited water...
If there afilter on the inlet hose it might need clening,if you have a partial blockage it will reduce the volume of water entering your appliance.Hope this helps.
1helpful
Flowtron LE-900D Leaf Shredder- Spinner flies off.
The screw is a common one, Make sure it is at least a grade 5 or grade 8. The o-ring may be another matter, but should be available at hardware and most definitely a hydraulic hose shop would have it.
5helpful
2answers
Hi. My bamix is not spinning. I can hear the motor revving when I turn it on, but the bottom part is not moving. Can you help please?
the coil part of the spinner is damaged,change the coil or check for whether the spinner is damaged.get to local repair shop and repair it.it will cost low.
2helpful
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
Heater hose is leaking on 97 Honda Accord
Put your car on jackstands then identify the hoses. They will be going into the firewall as a pair near the center of the car.
Because of the **** conditions, I would suggest taking it to a mechanic.
WASHER SOUNDS LIKE AN AIRPLANE TAKING OFF DURING SPINE CYCLE
Most likely a failed "spinner" assy. The roaring that you hear is the bearing telling you it's had enough and has gone on strike.
MAJOR job! If it's over 5 years old, I recommend calling a professional and get quotes. Then decide what you want to do.
If it's less than 5 years old, it should be under warranty. Contact Sears. Tell them you have a failed spinner and tub bearing assy. and have them do the repair.
*Just a quick note. You should use only HE detergent in these machines.
Tracy
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
