Clean filter on teco split system
How do remove the front cover
SOURCE: front cover and air filter
I'll leave it as is!
Posted on Jul 01, 2008
skrbin
  • 121 Answers
SOURCE: cant get heating to work
adjust temp e.g. 39 deg Celsius or high and turn on heat,but first you must turn off air conditioner then select heat rating and turn on a.c.
Posted on Jul 05, 2009
  • 81 Answers
SOURCE: How to remove cover on fujitsu split system head
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
Posted on Aug 29, 2009
  • 70 Answers
SOURCE: installation manual required for teco split
Is the unit an AC only or a heat pump?
Wiring to the units should in the manual or online.
Both units proper house voltage to inside unit and outside unit.There will also be a two wire low voltage cable between thr two.This is so the inside unit can turn on the higher current draw of the compressor in the outside condenser unit thru it's relay.If you have a heat pump there will also be a set of two wires to the 4 way gas valve in the condenser unit to change from heating to cooling mode,a set of two wires to control the on/off function of the fan in the condenser unit when it needs to defrost and mayby a two wire set to a themal sensor in the condenser to sense if it is frosting up when system is in heat mode.
Try to get a wiring diagram and if you can't get to the point where you understand how to wire the unit don't guess! Call someone who knows wiring or call a pro, he can you money over the cost of replacing parts if unit is miswired.
Posted on Oct 06, 2009
  • 1196 Answers
SOURCE: Hi, I need an operation manual
I will advice you check manualsonline.com for the operation manual of your device.
Posted on Mar 13, 2011
How do I remove the cover from a split system?
open up the front cover as if removing the filters
along the bottom of the main cover you will find 3 screws
undo then , lift forward and up with the main cover and it separates from the fixed unit on the wall
that is all you can remove as the main unit is fixed with the popes and drain on place
Dec 01, 2015 | LG Heating & Cooling
I have a teco split system which stopped working the stand by light has gone off too. Can I fix it.... Lost maual
call teco tech support and they will send you a free operator manual and probably refer you to a local service shop.
Jan 04, 2015 | Heating & Cooling
Teco LS1209Y faults pre-def
How do you take the cover of to get to the filters
Oct 16, 2012 | Heating & Cooling
Sir, I would like to clear the filter. I have a split AC. Can you please explain how to remove the filter from the AC Unit Mohideen
you have to remove the front cover to access the filter. The cover should be held in with push button retaining clips. After you remove the cover the filter resides in front of the evaporator.
May 02, 2011 | Samsung AS18A6RB Air Conditioner
The filter looks very durty how do i clean it
If it is split unit, lift the front cover up. and gently remove the filter. Clean with warm water. Don't use any detergent. And re fix gently, and close the top lifted door. Helpful?
Dec 20, 2010 | Heating & Cooling
Cant get air con to work it is a teco air conditioner
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Mar 01, 2009 | Heating & Cooling
Thankyou
Mat
Feb 21, 2009 | Fujitsu 18R1 Air Conditioner
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
